Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 06-11-2013, 06:55 AM   #1
madeouttaglass OP
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,618
$2200+ for truck A/C repair?
The compressor on my 2001 Tacoma seized up recently. When you turn it on the clutch tries to engage and it smokes. The truck is otherwise in mint condition and I'd like to have everything right. While we only need A/C a few weeks a year it also goes on with the defroster which we need about six months a year. The estimate is about 1/4 the book value of the truck. Any less expensive alternatives besides taking the belt off?
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 06-11-2013, 06:57 AM   #2
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,924
junk yard
vwboomer is offline   Reply With Quote
Old 06-11-2013, 07:07 AM   #3
SamRus
SamRus's Avatar
Oddometer: 306
Be careful with Junk Yard AC compressors.
I got one for my Camry, and it didn't turn out too well.
The body of the compressor consists of 2 large halves, and on the one I got, the gasket between 2 halves leaked. Since the compressors are not serviceable, the gasket is not something you can buy, so the whole compressor was junk. It put out pressure, and ran, just leaked, so the whole exercise was pointless.
And if you don't have your own vacuum machine (to suck the old freon & air out), you'll have to pay someone for the labor twice, regardless whether you're good at wrenching or not.
1984 Honda CB650sc - Nighthawk - with 33K miles - Fuelly Log
1982 Honda CM450a - Hondamatic - with 11K miles - Fuelly Log
2007 Kawasaki Ninja ex250 with 29K miles - Fuelly Log - [SOLD]
SamRus is offline   Reply With Quote
Old 06-11-2013, 07:12 AM   #4
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 12,791
If you don't care about AC....Can it be gutted and a new pully put in so it is effectively an idler?
A-Bone is offline   Reply With Quote
Old 06-11-2013, 07:55 AM   #5
AZstrommer
Long may she wave!
AZstrommer's Avatar
Oddometer: 970
When my compressor blew up last summer (Tucson - 100+ for weeks at a time), I took the plunge and got a new compressor, drier, filter and evap on ebay and installed them myself. I took it to a shop to be charged. Works like a champ! The parts cost $400 and the servicing was about $80.
This was on a 2001 Toyota Echo. YMMV.
AZ
Every day I'm a little bit more like the person I've always wanted to be - Hedge36
We can't negate who we are, who we were, what we've done. Who we've loved, who we've hurt. Part of our human fabric. Who are are. I am the sum of all I have done before. I am imperfect, I am flawed. I am, however, aware of that. I desire happiness, I long for joy, always knowing the price, the balance. - Sabre
AZstrommer is offline   Reply With Quote
Old 06-11-2013, 07:57 AM   #6
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Are you sure the clutch isn't bad? That happened on my FILs Chevy van and he just changed out the clutch and the AC works fine.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 06-11-2013, 08:04 AM   #7
papalobster
With Gusto!
papalobster's Avatar
Oddometer: 13,694
Repalce the compressor yourself, order a new one from Rock Auto. Hook all both hoses and the one wire back on and find an independant A/C shop to evac and charge and you will be out maybe a total of $400 instead.
Stop by the local auto parts house and see if they have a, A/C bypass pulley for around $30.
papalobster is offline   Reply With Quote
Old 06-11-2013, 08:04 AM   #8
troidus
Oddometer: 15,727
AZ
I did something similar to an '85 T-15 Jimmy, but I replaced the entire gas loop because I switched to R-134a, so I was out $800 in parts, many of them GM factory parts.
If the OPs compressor shelled, the gas loop may be full of metal. I could see parts + labor for that being four figures. He may be better off doing what I did and just swap the whole loop himself, then have it evacuated, oiled, and charged in a shop.
troidus is offline   Reply With Quote
Old 06-11-2013, 08:06 AM   #9
madeouttaglass OP
The AntiHarley
Oddometer: 3,618
Thanks for the replies. I've built engines and transmissions successfully but have never touched A/C before. I'm thinking along the lines of AZstrommer and buying new- not rebuilt- parts online and replacing it myself. The two trips to a shop is what had me wondering if that kind of thing was done.
Any advice on what parts should be replaced? I've heard that a bad compressor often fouls other parts.
Sniper- Thanks, I will check the clutch before I buy everything.
Old 06-11-2013, 08:07 AM   #10
Trail Ryder
Your Hero
Trail Ryder's Avatar
Oddometer: 1,053
Puke
About $200 from here: http://www.rockauto.com/
Sounds like a case of Stealership Gouging.
Trail Ryder is offline   Reply With Quote
Old 06-11-2013, 08:10 AM   #11
madeouttaglass OP
The AntiHarley
Oddometer: 3,618
No doubt. I have done all my own work for decades. The one time I say screw it, let someone else do it and get a quote it drives me right back into my own garage.
Old 06-11-2013, 08:35 AM   #12
troidus
Oddometer: 15,727
You can try disassembling everything and washing the system out with denatured alcohol, then drying it with clean compressed air. The condenser and evaporator will be the PITA parts to get clean if they're fouled. Check the high side line between the compressor and condenser and if it's clean, the condenser and evaporator should be fine. You should replace the desiccant tank, regardless.
Old 06-11-2013, 08:48 AM   #13
Murf2
Oddometer: 834
Why don't you look for an independent shop to do it? Should be way cheaper than the dealer and they would have to back their work. One problem with doing it your self & having someone evac & charge, would be if you had a problem. I bet they'd say "not our fault" you did the install. It is easy to roach the new compressor with junk in the system. I don't know how it is where you are but we have a couple independent A.C./ radiator shops that are very reasonable.
Good Luck!
Murf
Murf2 is online now   Reply With Quote
Old 06-11-2013, 10:06 AM   #14
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Spend 20 hours doing all that, with no guarantee it'll work or buy a new one for 400 clams.....I vote new. At least he will know it works.
Old 06-11-2013, 11:55 AM   #15
troidus
Oddometer: 15,727
I meant the non-compressor parts of the gas loop, not the compressor itself. A rebuild of one of those is best left to a specialist.
Thread Tools
Times are GMT -7.   It's 03:30 AM.
