Old 06-11-2013, 02:41 PM   #1
Cdubs OP
made for adventure
Oddometer: 164
GS Stem and nut question
Guy is trying to machine some new stems for us in the group buy, does anyone know the answer to the bolded questions below?
Originally Posted by HPMGuy View Post
I read up on the stem issue on the other thread. It looks like the old nut from KTM had 20mm of threads and then used a ~3mm washer leaving ~17mm of engagement. The replacement nut has 12mm of thread height but only 8mm of engagement because of the wide thread relief at the bottom. Either one is fine for a KTM, but apparently the different bearing taper of the BMW bearings requires significantly more torque than the KTM stem/nut were designed to take.
I don't know if this is really a huge problem, as I could only find one instance of it happening. Never-the-less, it seems like a good idea to address the issue at this time. I have cancelled the order for the KTM stems and have placed an order for 7075 stock to machine them from scratch. I will maximize the thread engagement on both the nut and the stem.
Since the parts are being machined from scratch, maybe it would be a good idea to copy the thread pitch of the BMW stem bolt so torque values would remain the same for the BMW bearings? This might eliminate some confusion regarding setup. Does anyone know offhand what the thread pitch is on the BMW P/N 31 42 1457859 "Screw" used on the '87-'91 R100GS?
Cdubs is offline   Reply With Quote
Old 06-12-2013, 04:26 AM   #2
AliBaba
AliBaba's Avatar
Oddometer: 372
Maybe a bit off-topic but I changed head-bearings on my EXC the other day and had the same problem with the stem, but was able to clean up the threads a bit. The result was maybe okay for a slow enduro bike but I wouldn't used it on a fast and heavy GS.
Maybe increased weight and offset makes it worse?
There was also the same problem with the front wheel-axle, it works for now but a new one is ordered.
AliBaba is offline   Reply With Quote
Old 06-12-2013, 07:51 AM   #3
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 926
The thread size is 28mm x 1.5mm.
Pokie is offline   Reply With Quote
Old 06-13-2013, 12:48 PM   #4
Cdubs OP
made for adventure
Oddometer: 164
Thanks Pokie I passed this to HPMguy
Times are GMT -7.   It's 04:41 PM.
