Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-14-2013, 10:50 AM   #46
umitc
umitc's Avatar
Oddometer: 346
I think this is the difference; maybe what we don't need is ventilation. :-))))
umitc is offline   Reply With Quote
Old 06-14-2013, 11:13 AM   #47
Viajaendl
Oddometer: 18
Well... you can also put some cooler fans on the inside of both plats, but i dont think it will be a problem of heating if you do the plats.
It will just be hotter in there but it will go back and leave by the rear wheel. Dont think it must be a problem for any electronic or electric component there, for the simply reason that you can drive this bike in Africa with 45ºC-50ºC and it will be ok, it wont damage any component
Viajaendl is offline   Reply With Quote
Old 06-14-2013, 11:56 AM   #48
umitc
umitc's Avatar
Oddometer: 346
Tomorrow I will have a couple of plates cut and mounted if I can.
Old 06-14-2013, 01:52 PM   #49
Tancakar
Tancakar's Avatar
Oddometer: 367
can you put up here ? and where from you going to get them cut ?
Tancakar is offline   Reply With Quote
Old 06-15-2013, 04:03 AM   #50
umitc
umitc's Avatar
Oddometer: 346
Woke up late, but I will try to do something. :-)))
Old 06-16-2013, 10:42 AM   #51
coast range rider
Oddometer: 175
The engine radiates heat. The radiator creates a flow of hot air. The exhaust is hotter still. The catalytic convertor makes the exhaust hotter yet.
I would think removing the cat, the hottest part on the bike that can be removed (without turning the bike into a statue) would help better than anything. I have not seen mention of this being tried.
Anyone?
coast range rider is offline   Reply With Quote
Old 06-16-2013, 10:48 AM   #52
umitc
umitc's Avatar
Oddometer: 346
Because it's not removable; ypu may have warranty issues. How extent do you believe the heat will drop?
Old 06-16-2013, 11:03 AM   #53
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,831
Thanks to this thread . . . I finally addressed the KTM SuperMoto voltage regulator/rectifer heat issue . . . Which reduces the heat on your lower legs as a bonus . . . by adding a frame shield and relocating the VR.
There is a gap (top left) that allows free flowing air over the VR to reduce heat. You could allow a similar gap on the 1190 frame . . . To allow airflow etc:
Compared to the stock VR location above the Y pipe:
Motorcycles . . . my Happy medicine.
Live to ride . . . ride to Live . . . just like breathing to Live . . .
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
mcmann is offline   Reply With Quote
Old 06-16-2013, 12:50 PM   #54
Trailblazin
Oddometer: 110
Thanks for beta testing this bike for USA. Love you guys.
___________________
'15 BMW R1200GSA
Sold '13 BMW F800GS
Sold '12 KTM 690 Enduro
Trailblazin is offline   Reply With Quote
Old 06-16-2013, 02:52 PM   #55
Tancakar
Tancakar's Avatar
Oddometer: 367
Anyone?
removing catalytic convertor is almost impossible . you need a full system to remove all of it then also needs tuning i guess.
Old 06-16-2013, 11:17 PM   #56
coast range rider
Oddometer: 175
Full exhaust system, no cat, and remapping, YES
Old 06-17-2013, 09:10 AM   #57
990
Krap To Maintain
990's Avatar
Oddometer: 192
Not many guys moaning about the heat on the 1190 R, the seat is not 2 pieces and is much thicker at the front and feels more comfortable to me. I don't really feel the heat on my adventure, but the day temps don't go over 20 degrees Celsius. My seat is set on high, this might help as it is further away from the pipe(I think).
P.S. heard the new Akro pipe with the DB killers removed, sounds alot like my 990 with FMF's on with the DB killers out. My neighbours are going to love it
Smith & Wesson the original point and click interface
14 BMW GS 1200 LC
13 KTM 1190 Adv
08 KTM 990 Adv
990 screwed with this post 06-17-2013 at 09:21 AM
990 is offline   Reply With Quote
Old 06-17-2013, 09:28 AM   #58
Tancakar
Tancakar's Avatar
Oddometer: 367
I though you can't remove the db killers so it is possible . Is it need drilling or cutting ?
Old 06-17-2013, 09:35 AM   #59
990
Krap To Maintain
990's Avatar
Oddometer: 192
Not sure - I saw it at the dealer, I think he had to drill the pop rivets out, not sure which ones, but I would assume the ones on the carbon fibre cone. I will check with him. There were 2 bikes that just had Akros fitted and one had the db killers removed and it sounded fantastic
14 BMW GS 1200 LC
13 KTM 1190 Adv
08 KTM 990 Adv
Old 06-17-2013, 09:55 AM   #60
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
this stocker has the baffle removed and welded up
MookieBlaylock is offline   Reply With Quote
Times are GMT -7.   It's 04:11 AM.
