Old 06-11-2013, 06:45 PM   #1
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,345
Shims for Adjusting the Valves?
I've not started my valve adjustment job yet, but will this or next weekend.
I have a completes set of KTM shims, several of each size, that I bought a while back for my 250XCFW.
Will these same shims work in my 990??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 06-11-2013, 07:06 PM   #2
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,714
Dunno. Harley shims work, though. Check out the HOW. www.ktm950.info.
Orangecicle is offline   Reply With Quote
Old 06-11-2013, 08:10 PM   #3
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,898
Are they 10mm diameter?
Motorcycles are Life
If I am not riding . . . I feel like I am missing out on living . . .
mcmann is offline   Reply With Quote
Old 06-11-2013, 09:26 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Those shims won't work. The dirtbikes use a smaller shim. The street bikes (LC8 engine, LC4 690, 350 exc/xcw, 450/500 exc/xcw, RC8) use a 10 mm shim.
You are in luck, because HOT CAMS now makes a cheap shim kit.
Cyclebuy.com has them.
"Son, you can't do both"
Old 06-12-2013, 12:38 PM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,856
The HOT CAMS shim kit is in .5 increments, the Harley dealer sells them in .25 increments so between the two you can get the valves exactly where you want them more or less.
They are the shims for the VRod
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 06-12-2013, 10:40 PM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,980
Here is another option, with 0.05 increments
http://www.rockymountainatvmc.com/p/...Valve-Shim-Kit
Cheers
gefr screwed with this post 06-12-2013 at 11:15 PM
Old 06-13-2013, 02:47 AM   #7
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,345
I ordered the Hot Cams Kit from Cyclebuy.
Now I will have a set for small KTM bikes (and no small KTM bike), and
a set of 10mm for a big KTM bike.
Thanks for the info
Times are GMT -7.   It's 08:29 PM.
