Old 06-11-2013, 07:18 PM   #1
keener OP
Speed changes you.
keener's Avatar
Oddometer: 931
Whats the tricl to put a rear tire on rim, seems impossible
04 ADV 950
keener is offline   Reply With Quote
Old 06-11-2013, 07:29 PM   #2
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,513
Gotta have the opposite side of the tire down in the dish of the rim (where the spokes connect).
Also review Neduro's Tire Changing Tutorial.
Old 06-11-2013, 07:38 PM   #3
Deepc
Oddometer: 299
Opposite side of the tire needs to be flush with the center of the rim like mentioned above.
Use lube. I use dish soap and water.
Heat up the tire in the sun if possible.
Wear gloves. I always tear up my hands.
Don't give up.
Deepc is offline   Reply With Quote
Old 06-11-2013, 07:54 PM   #4
txbear55
Oddometer: 265
Lube, more lube (that's what my wife says....), take little bites with the tire irons, and keep the opposite side deep in the well. Did I mention more lube????
txbear55 is offline   Reply With Quote
Old 06-11-2013, 07:56 PM   #5
keener OP
Speed changes you.
keener's Avatar
Oddometer: 931
YES THANK
04 ADV 950
Old 06-12-2013, 07:08 AM   #6
Deepc
Oddometer: 299
One more thing. I put the rear tire on with the disk side up if I don't have a wheel stand available. I worry about warping the disk. Glad you got it on there.
Old 06-12-2013, 07:21 AM   #7
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
THE MOST IMPORTANT THING!!!!
Don't let your wife catch you using her hair drier to heat your tire.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 06-12-2013, 07:32 AM   #8
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 19,871
I just noticed the ratchet tie down around the axle and lever.
Glad you got it on, OP.
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 06-12-2013, 07:46 AM   #9
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,174
After a couple years in Latin America I got accustomed to paying people to put my tires on for me. I recently mounted my rear tire for the first time in a few years and it was way easier than I recall, I must be learning something.
For me I tried to focus on keeping the tire within the bead as I was spooning it on. I did this one on the ground but I prefer a good barrel for changing tires.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 06-12-2013, 09:47 AM   #10
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,856
Use small blocks of wood on the opposite side to keep the wheel in the dish of the rim, I travel with about 4-6 small derlin blocks I used for just that purpose makes changing the wheels much much easier.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 06-12-2013, 05:37 PM   #11
keener OP
Speed changes you.
keener's Avatar
Oddometer: 931
I was pulling every trick I could come up with ...pushing it into the dish on the opposite side did it with little effort.
04 ADV 950
Old 06-12-2013, 06:03 PM   #12
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,513
Motion Pro Bead Buddy
Times are GMT -7.   It's 03:47 AM.
