Old 06-11-2013, 09:47 PM   #1
dirtriderbloke OP
Oddometer: 106
KTM EXC Oil Level/Change??
hi. i just have a general enquiry. i did around 10-12 hours of riding since a previous oil change and checked the oil level in the small glass and i couldn't see any oil showing in it. so i decided to drain the oil and do an oil change and measure/calculate how much oil in total was drained out of the bike and it was 770ml that was left in the bike from when i drained it. The bike takes 1.2 litres in total. I know oil degrades with the heat and over time but i didn't think that much over 2-3 rides. i topped up straight after i got home from my last ride as soon as i noticed the lack of oil level in the glass, but im wondering, would that have done any damage? and what level is it meant to or able to go down to before problems start persisting with the bike/engine(what is a safe level amount)?? i was told by other KTM owners that as long as it's got more then half the capacity the bike takes in total of oil when it's drained, it should be alright but just want to check and confirm. any help/advice is greatly appreciated, thanks. Also, the bike has had a fresh top and bottom end done about 60 hours ago.
dirtriderbloke is offline   Reply With Quote
Old 06-11-2013, 09:50 PM   #2
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
what year? CC's', etc..
Btw- the 530's burned oil a bit, but i doubt you did any damage, unless you were redlining it like a redneck with a passion for Harley noise.
Best of luck!
Happy Trails Y'all.
It's not about tha bike nor tha ride; it's about tha adventure in life we all seek. Great memories are made of taking tha trail less traveled and explored.
Tha Rick is offline   Reply With Quote
Old 06-11-2013, 09:51 PM   #3
dirtriderbloke OP
Oddometer: 106
Best of luck!
oh sorry. KTM 450 EXC 2004
Old 06-11-2013, 09:55 PM   #4
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Top end include new valve guides and seals? or just a ring job.
Happy Trails Y'all.
Old 06-11-2013, 09:56 PM   #5
dirtriderbloke OP
Oddometer: 106
nah complete top end including valves, seals, gaskets, rings, piston, etc + complete new bottom end including bearings, conrod, etc.
Old 06-11-2013, 09:57 PM   #6
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
How's the plug look? with a carb'd bike it can be tough to tell whether it's burning rich or oil is getting in..
Also take a look at the end of the exhaust- is it a bit oily?
Happy Trails Y'all.
Old 06-11-2013, 09:59 PM   #7
dirtriderbloke OP
Oddometer: 106
checked the plug, it is a nice crispy brown colour not too rich and not too lean and nothing from the end of the exhaust
Old 06-11-2013, 09:59 PM   #8
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Sounds a bit like ring's to me. I know the "break in" procedure is to take it easy, but I've had better luck with about 3 heat cycles and then do a few hot lap's to seat the ring's.
Edit- that's just me...but it seems to work.
Happy Trails Y'all.
Old 06-11-2013, 10:01 PM   #9
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
So 2-3 rides between oil changes- how long and terrain?
Happy Trails Y'all.
Old 06-11-2013, 10:03 PM   #10
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Oh, and if I run low on oil during a ride, I'll change the filter just in case.
Happy Trails Y'all.
Old 06-11-2013, 10:04 PM   #11
dirtriderbloke OP
Oddometer: 106
1st 2 rides were 4 hours long and the last ride was 3 hours long. terrain was mainly fire trails & single trails.
Old 06-11-2013, 10:07 PM   #12
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Sounds like normal oil loss for an older KTM, regardless of the rebuild.
Fill 'er up after about 4-5 hour's of run time, and grip it and rip it!!
But that's just my opinion...there may be other's who chime in later. Their opinion's are just as valid.
Happy Trails Y'all.
Old 06-11-2013, 10:09 PM   #13
dirtriderbloke OP
Oddometer: 106
ok cool. thanks for the help mate. ill definitely be keeping an eye on the oil levels and taking other people's advice/opinions into consideration if they chime in later :)
Old 06-11-2013, 10:09 PM   #14
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
BTW- I've had 525's, 530, a couple of 950's and a '12 500 and they all consumed a bit of oil.
Happy Trails Y'all.
Old 06-11-2013, 10:12 PM   #15
dirtriderbloke OP
Oddometer: 106
yeah it makes sense for it to do that. i was just mainly concerned about weather i rode it with not enough oil in it or not
Times are GMT -7.   It's 08:31 PM.
