Old 06-12-2013, 12:16 PM   #16
fossriver OP
Oddometer: 73
Thanks for the positive comments everyone. Took her out for a ride, everything works great!
fossriver is offline   Reply With Quote
Old 06-12-2013, 12:22 PM   #17
rpet
Awesometown
rpet's Avatar
Oddometer: 820
you lost me at the vinyl wrap, but otherwise nice build!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 06-12-2013, 12:36 PM   #18
fossriver OP
Oddometer: 73
The nice thing is it's really just a big, removable sticker. I thought about doing the vinyl in solid white. But, I trusted my instincts that it would not turn out perfect, so I chose a pattern that would hide wrinkles, and small bubbles.
Old 06-12-2013, 12:39 PM   #19
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
That is a TM33 not a FCR carb right?
You can lose a couple more pounds by not attaching the plate to the rear "sub" frame, and removing that thing.
I see that you have the dirt grab bar or cut the turn singal mounting tabs. Flush mounts work good in this case. Small taillight right on the fender.
Try changing out the oil in the shock. I went to a dirt shock from a SE shock. Put new oil in it before installing and it was quite an improvement. You already have a dirt shock (so I am told with a 98/99SE).
MrPulldown is offline   Reply With Quote
Old 06-12-2013, 12:52 PM   #20
fossriver OP
Oddometer: 73
Sorry for not clarifying. It is the TM 33, but the improvement is similar to when I put the FCR on my DRZ. It was bogging at about 7k, so I removed the air box screen, opened up the hole to a full 3x4",and added two discs two the pipe for a total of 7. It pulls clean now all the way through now. I still have a dozen discs,if anyone needs a few, just holler. I did cut off the turn signal tabs, and the tail light I added has integrated flashers. It's tiny, but bright. I will try refreshing the shock before changing anything else in the rear suspension. Thank you!
Old 06-13-2013, 07:05 AM   #21
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 408
Talk to me about that horn....water proof? I keep drowning my F250 horn, then i need to take it off and get all the water out before it will work again....I guess i could find a shallower route to take, ..... nah.
2011 UPAT
rubberband is offline   Reply With Quote
Old 06-13-2013, 08:24 AM   #22
fossriver OP
Oddometer: 73
That's a great question, I'll let you know next time I wash it, or do a water crossing. I put Silicone on the connections, because they were a bit loose. For now here's a link to the item http://www.ebay.com/itm/BLUE-SUPER-L...772915&vxp=mtr
The Seller also has dual horns for auto applications if that's what you mean by the f250. I always aim my truck at the biggest puddles too!
Old 06-13-2013, 09:24 AM   #23
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 408
well kinda....I put the F250 horn on my DR
2011 UPAT
Old 06-13-2013, 09:54 AM   #24
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,728
Will those stickers work on the fork boots?
plugeye is offline   Reply With Quote
Old 06-13-2013, 10:11 AM   #25
fossriver OP
Oddometer: 73
I was curious, so I just gave the horn a good dousing with the hose. Still sounds like an angry goose on steroids.
Old 06-13-2013, 10:14 AM   #26
fossriver OP
Oddometer: 73
I think I am failing to understand the question. Vinyl wrap on the rubber fork boots? That's not going to work. The vinyl is only flexible when hot, and it would be nearly impossible to apply. You could try tie-dying them. Make sure you post pictures of the results.
Old 07-06-2013, 08:18 PM   #27
fossriver OP
Oddometer: 73
I decided to lose the vinyl wrap, and added an Acerbis 4.25 gallon tank, a Maier rear fender and a Seat Concepts saddle. I love this bike!
Old 07-07-2013, 09:10 AM   #28
gmansyz
gmansyz's Avatar
Oddometer: 25
I Likey!
I like it! Did you know the off road only had a different cam? When I had my '97, it was lacking in power as well. I added a kick starter too. But it never ran like I thought it should and was tough to get it to wheelie.
So, I am thinking to get another one.
Very nice what you did with yours!
G
Katana Awaiting a Turbo Busa engine.
Reconsidering another DR350
gmansyz is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
