Old 06-12-2013, 10:02 AM   #1
1reddawg OP
1reddawg's Avatar
Oddometer: 2,257
Talk about a pain in the a$$
About 5years ago the steering locked up on my 04 GSA
Had to get a bunch of manly men to lift the bike into the back of a truck,take it to Daytona BMW and almost 500 clams later,I got my bike back.They had to replace the locking mechanism ,the dealer said they could never find out why it locked up.So fast forward 5 years and stupid me mistakenly locked the front end again 😡😡low and behold the front end would not unlock again 😡😡😡😡.do you think The Beemer shop who worked on it before would work on it at N/C or am I just waiting my time contacting them?
Signed
Frustrated in Florida😡😡😡😠😠😠
Current ride
2012 BMW Triple Black GSA
1reddawg is offline   Reply With Quote
Old 06-12-2013, 10:21 AM   #2
Lensgrinder
Oddometer: 1,317
After five years gone by I think you are back at square one.
I don't think they would fix it again at no charge.
It is not too difficult to remove upper clamp and find out why it continues to do this.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Old 06-12-2013, 12:36 PM   #3
Callisto224
Callisto224's Avatar
Oddometer: 983
I agree with Lensgrinder, after 5 years you're pretty much on your own. Although I'm sure the dealer will gladly charge you another 500 buck to fix it!
There's gotta be a simple way to take it apart and find the problem. Do a search here, must be a thread somewhere that explains how!
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 06-12-2013, 12:42 PM   #4
mexipike
Oddometer: 411
I wouldn't pay anyone to fix a problem like that as I'd imagine most of what you're paying for is the time spent trouble shooting. Some people here surely have an answer for you, and maybe this time you can fix it right!
mexipike is offline   Reply With Quote
Old 06-12-2013, 12:45 PM   #5
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,975
or just snap the lock since you don't use it anyhow
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 06-12-2013, 05:25 PM   #6
1reddawg OP
1reddawg's Avatar
Oddometer: 2,257
The only problem is that i cant get the ignition key put either.I'm probally gonna have to bite the bullet and get a whole new Ignition switch and Steering lock mechanism.At least this way i can lock the front end again.Even tho i dont know who would want to steal this old War Horse!!
Current ride
Old 06-12-2013, 07:40 PM   #7
trc.rhubarb
Oddometer: 1,975
Can't get the key in either? You mean turn or can't even insert the key?
Would it be correct to assume you have twisted the bars while trying to turn the key?
Follow me here
Old 06-13-2013, 04:57 AM   #8
1reddawg OP
1reddawg's Avatar
Oddometer: 2,257
Can't get the key out of the ignition .I tried turning the key back and forth while trying to turn the handle bars and the key is now stuck with the running lights on ,which is about 6 o clock on the ignition switch
Current ride
Old 06-13-2013, 07:35 AM   #9
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,545
There is a 05 GS in my shop. Just went and looked and as I tought not too waterproof the lock mechanism. Can you move the key a little and dump lube in there, could be corroded. I should lube that one, all them tiny springs in the mechanism, may lock the key in there if they corrode.
Ooops...ran back to the shop sprayed a little Teflon lube in there, pushed it in with compressed air to spread it. Key action is much smoother.
I'll go look again, there may be a drain hole at the bottom to evacuate moisture. Maybe a way to lube the steering lock.
Have tools, will travel!
H96669 is online now   Reply With Quote
Old 06-13-2013, 07:49 AM   #10
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,560
I don't know if this is useful info reddawg - but recently my steering lock wouldn't lock. Sounds like yours has stuck SHUT - mine was stuck OPEN.
Eventually I gave it a good dousing of WD40 from underneath (had to put my hand plus WD can under the triple tree to get access). Awkward space to work in. Applying WD from the top - and to the lock barrel itself, did nothing for me - I had to come at it from underneath
This freed up the mechanism.
good luck - and keep us posted.
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Old 06-13-2013, 10:07 AM   #11
mycirus
mycirus's Avatar
Oddometer: 197
Try some Fluid Film. Its works better than WD40. Pick some up at your local John Deer dealer. Stuff works wonders.
mycirus is offline   Reply With Quote
Old 06-13-2013, 09:42 PM   #12
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,753
If you can't get the key out it's probably not fully locked. I'd douse it in juice and then actually try and 'lock' it more, then when the key comes loose you may be able to re-insert and unlock. Easy goes though, forcing it will just screw it up. The locking peg could be mis-aligned and grabbing were it goes in. You could try some bolt ease or penetrating oil on that peg too.
The LAST thing I would do would be trailer and $500+.......it would be a week of f'ing around before it came to that, even then I'd come up with some other remedy.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Times are GMT -7.   It's 08:20 AM.
