Old 07-07-2013, 11:52 AM   #46
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,362
I can't really make it out in the pics but just a FYI because I BTDT.
Drill holes and use zip-ties to hold the hooks of your fender bags in place. I had the rear one come off my bike and get destroyed in the rear wheel. Those bags are these handiest for these bikes but the vibrations of running dirt can get the straps to slack off a bit.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 07-08-2013, 08:49 AM   #47
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,584
...my my, what a coincidence, happened just yesterday...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog screwed with this post 07-08-2013 at 09:51 AM
Rapid Dog is offline   Reply With Quote
Old 11-29-2013, 09:33 AM   #48
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,584
Question Tireism
....hmmm...found my old thread. I must be the only person in the Mojave working today.
Saw the LBtoV crowd taking off to day on the way to work...
Anyhow, let's talk tires for a minute...
The KTM manual calls for a 130 rear (I've even read 140...).
I put on a Pirelli Scorpion (front and rear 130) and the rear seemed sorta big, then went to the MotoZ Tractionator in the same size, which seemed huge.
I measured the two side by side and the Pirelli was actually taller.
The MotoZ is a great tire, predictatble when steering with the rear, albeit very noisy on the hardpack and street.
All that said, the bike in general seems a bit twitchy in a straight line. Not something I like.
My friends '09 450EXC-R calls for a 120 rear.
I'm thinking about going down to a 120. Even thinking about a 110 rear...
Any thoughts?
Old 11-29-2013, 10:25 AM   #49
jar944
jar944's Avatar
Oddometer: 730
Any thoughts?
True (actual measured) width's are really all over the place with respect to manufacturer sizing. I like a 140 (IRC m5b) as its the widest biggest knobbiest tire short of a terror flex available (and doesn't weigh 100lbs like the Terra)
That said, the wide rear is a trade off as it does not turn in as well and tends to push the front more than narrower tires. It really really shines on hills though.
The wide rear should have no [negative] effect on the straight line stability of the bike, that seems like a sag/suspension issue.
jar944 is offline   Reply With Quote
Old 12-09-2013, 03:26 PM   #50
soupamoto
Singletrack Jedi
soupamoto's Avatar
Oddometer: 75
I've built a lot of RFS supermoto and dual sport bikes (frame up). The earlier swingarms were not as wide as the later (like '04 I think). Hard to fit a wider tire.
I've always run a 130/80 (usually Michelin S12) on my '01.
Any thoughts?
2009 KTM 690 Enduro R SMC Supermoto, 2013 KTM 450 XC-W Dual Sport, 2015 KTM Freeride 250 R, For Sale: 01 Thumper Racing KTM 453 Street Supermoto, 08 Honda CRF150F Dual Sport
soupamoto is offline   Reply With Quote
Old 12-09-2013, 03:45 PM   #51
soupamoto
Singletrack Jedi
soupamoto's Avatar
Oddometer: 75
Originally Posted by GR0NK View Post
If you follow the 400 discussions anywhere, you'll surely come across the mention of the 453. The 453 is the best RFS motor KTM never made. Basically it's the 400 crank (short stroke) with a 525 cylinder (and a special piston from Thumper Racing) and it bumps the displacement to 453cc. You toss the anemic 400 cam and use the 5521 cam (stock cam on 450 and 525 EXCs) and that gives you a great all around motor for low bucks. It's still docile on the bottom but it comes alive on top and revs out good due to the short stroke and the better cam.
Yep. That's what I did to my '01, and love the 453 motor. If you ever get a chance to install one, go for it.
Old 12-11-2013, 08:32 AM   #52
GR0NK
GR0NK's Avatar
Oddometer: 2,362
I'm building a special bike and I may just do that. I'm taking my 01 SX (started life as a 520) and making a 400 SEXC. (pronounced sexy lol)
Basically, it will be the transmission from a 250 EXC (super close ratio 6 speed, even closer than the XC gearbox) and I'm putting a 400 crank in it. I'll probably end up making a 453 out of it.
Sean
Old 12-11-2013, 11:46 AM   #53
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,584
Thumb
...I've just bought a 120 Kenda. Well see what happens.
It doesn't appear any less in width but it's a good 1/2 to 1" shorter than the MotoZ.
MotoZ for sale!!!!
Old 12-11-2013, 12:46 PM   #54
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 144
My 01 Ktm 453 exc
I loved this bike and did 2 seprate frame off resto's on it. I just sold it 2 years ago because I could not get it dual sported and bought a 500 exc. The 453 motor is magic I feel like I could ride that bike faster than my 500 but I also had that bike for 10+ years. You have a great bike and platform to work with and if you get a chance go with the 453 kit make that bike electric. here is a pic of my 453 rite after my last resto. Also if you get on ktm talk and can find any of the NOST SS suspension valves frt and back, Grab them.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Times are GMT -7.   It's 03:06 PM.
