Old 06-12-2013, 08:16 PM   #1
Sauer 1979 OP
Oddometer: 25
GS 911 Fault code help needed!
Hi all,
I ran the GS 911 over a friends R1150 GS 2003 model bike.
He wad complaining about the surging of the bike at 2000 - 3000 rpm.
The error code is as follows.
304: Oxygen (Lambda) Sensor Circuit Malfunction, Signal implausible.
This fault occured 57 times.
The fault is not present now.
4400: Lambda-Control, Upper control limit reached
This fault occured 60 times.
Has anyone had any experience with this?
What should we look for?
It looks to me as we might need a new oxygen sensor.
Any help would be great!
Sauer 1979 screwed with this post 06-12-2013 at 08:16 PM Reason: Colour change!
Sauer 1979 is offline   Reply With Quote
Old 06-13-2013, 02:17 AM   #2
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,634
Pretty simple - The lambda probe isn't functioning correctly. Replace said item.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 06-13-2013, 03:04 AM   #3
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,260
Could be as simple as it is a bad sensor.
Connect your GS-911, get the bike fullymwarmed up and then read the realtime values. Idle the bike. It should indicate that lambda control is: On. Then plot O2. If the plot looks something like these http://www.hexcode.co.za/techinfo/lambda then these then your o2 sensor is functioning at least part of the time. If not the sensor may be dead.
It could also be that you have leaking hoses in the tank and at higher powers the lambda control reaches its max and can't add enough fuel to get to lambda=1, which is the error.
roger 04 rt is offline   Reply With Quote
Old 06-13-2013, 10:44 AM   #4
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,522
Surging...Have him install a set of Autolite 3923 spark plugs and clear the stored codes. Disconnect the battery-1 min-reconnect the battery and re-learn the TPS by fully opening and closing the throttle several times with the engine off. Cycle key again and take the bike for a ride.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 06-13-2013, 05:23 PM   #5
BluByU
BluByU's Avatar
Oddometer: 497
Yep Steptoe is on the money, Replace the O2 and pull the ECU fuse to reset the fuel trim after the O2 has been replaced.
BluByU is offline   Reply With Quote
Old 06-13-2013, 07:21 PM   #6
Sauer 1979 OP
Oddometer: 25
Thanks to everyone that have replyed.
I will let you know the outcome!
Old 06-14-2013, 01:17 PM   #7
Bigdog54
MX X-Over Adventurer
Bigdog54's Avatar
Oddometer: 351
At the risk of great online ridicule.....what the heck is a Lambda Probe? And where the heck is it?
"Never spit at a competitor when you're wearing a full-face helmet"
Bigdog54 is offline   Reply With Quote
Old 06-14-2013, 01:39 PM   #8
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,108
Google is your friend................
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 06-15-2013, 09:04 AM   #9
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,010
It's the fancy name for an oxygen sensor (O2 sensor).
It's screwed into your exhaust pipe somewhere between the heads and the catalytic converter.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Times are GMT -7.   It's 03:16 PM.
