Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 06-14-2013, 06:29 PM   #1
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
XT660R suspension
Bloody finally got the forks back from DAS ,only took 4 months to have them
re-valved , sprung , shortened & travel reduced , Couldn't see a lot of point haveing
forks with 300mm of travel on a bike with 250mm of ground clearance...
CR250 forks / Ohlins shock , hopefully will make it a diffrent bike..
replaced the CR disc with a 320mm .. didn't think the little CR one would
pull up a 170kg XT to well.. hopeing it might stop...
Now just need to find a head light for the screen.. Any ideas on LED lights
that will pass WOF ?
A Ohlins S46DR1 shock out of Germany was only $692.35 NZ on my door step..
quoted $1300 here for the same shock..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ screwed with this post 06-14-2013 at 07:47 PM
Pete-NZ is online now   Reply With Quote
Old 06-15-2013, 11:06 PM   #2
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 332
Who manufacturers that screen Pete?
www.RemoteMoto.com
RMOTO is online now   Reply With Quote
Old 06-15-2013, 11:33 PM   #3
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
Cost $180nz on my door step... I'm very temped to take a mold off it
as I have to sand it , paint it blue...
http://www.rallyraid.co.uk/shop/prod...?prod=RRXR650F
Pete-NZ screwed with this post 06-15-2013 at 11:38 PM
Old 06-16-2013, 01:52 AM   #4
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 332
That looks sharp on the XR, it'll be interesting to see how it looks fitted to the XT
www.RemoteMoto.com
Old 06-18-2013, 02:30 PM   #5
GPS MAN
Lost!
GPS MAN's Avatar
Oddometer: 71
Hey Pete~that's going to be a pretty trick bike when you finish it...
GPS MAN is offline   Reply With Quote
Old 06-18-2013, 11:52 PM   #6
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,002
I love it when new parts turn up
Cool project Pete
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 06-19-2013, 08:39 PM   #7
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
You should be able to do some sweet jumps with that lot bolted in
I had a bit of a look around recently when I upgraded the 640 light & didn't see anything Hi/Lo in LED. I'd be inclined to get the cheapest thing that fits in the hole with a std H4 then get a badass LED spot like this alongside it to augment high beam.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-21-2013, 05:29 PM   #8
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
Cheers
Clint
I did find one on e-bay... had 3 LEDs , one for low / all 3 for high...
But its a 7" round replacement unit..
If they made a square unit it would be perfect..
HERE.............
http://www.ebay.com/itm/Universal-Mo...item2c6fe6a368
Pete-NZ screwed with this post 06-21-2013 at 05:37 PM
Old 06-21-2013, 07:20 PM   #9
Padmei
enamoured
Oddometer: 3,654
Looking forward to seeing it fly Pete
Padmei is online now   Reply With Quote
Old 07-05-2013, 04:03 AM   #10
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
Well I need something to ride while the XT is in bits....
06 TTR250.... quite a trick wee bike for a budget Yamaha.
Rear shock has spring pre-load / rebound & compression damping....
Forks have air valves & adjustable pre-load... 6 speed box...
Elec & kick start...275mm/11" wheel travel...Weight 130kgs fully wet...
Came with a Yamaha GYTR pipe... Has a nice new set of
Michelin AC10's on it now....
It looks as if it uses the same friction plates as the WR250F... So it
will get a Rekluse EXP...
PS.... Whats the best way to carry a step ladder on a bike..
Pete-NZ screwed with this post 07-05-2013 at 07:31 PM
Old 07-05-2013, 07:31 PM   #11
andy mac
Oddometer: 56
Hey Pete since moving to Christchurch you seem to have developed an affliction for buying blue Yamahas - XT660R, WR250F, TT250R. Has Gerry Brownlee appointed you saviour of the Chch motorcycle industry or is it your midlife crisis? Whatever you must be having fun.
andy mac is offline   Reply With Quote
Old 07-05-2013, 07:37 PM   #12
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
LOL.. I didn't get the WR in the end.... Thought about it desided the motor was a bit to short lived for what I wanted to use it for...
Pete-NZ screwed with this post 07-05-2013 at 07:45 PM
Old 07-06-2013, 12:59 AM   #13
Night Falcon
Adventure NZL
Oddometer: 2,002
yeah Pete, any more bikes and you'll need a dealers licence
All good though, can never have enough bikes
My EXC530 Adventure
My KTM690 Adventure
Old 07-06-2013, 01:36 AM   #14
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
Dam small shop with only 3 bikes....
XTR / TTR / Monty Cota...
Old 08-18-2013, 12:34 AM   #15
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 739
the on again / off again project is on again..
Now I have to sort these steering stops out.... I haz a cunning plan..
Pete-NZ screwed with this post 08-18-2013 at 12:41 AM
Times are GMT -7.   It's 01:06 AM.
