Go Back   ADVrider > Riding > Regional forums > Alaska
Old 06-15-2013, 04:38 PM   #1
Madmardigan OP
Generally confused...
Madmardigan's Avatar
Location: At the corner of Space and Time, Mizz-oo-la, MT
Oddometer: 128
Help finding cables....
Greetings Northern Inmates:
I recently purchased a 1200 GS Adventure and will begin the (circuitous) trip home on Wednesday (currently holed up in Talkeetna). This bike came with the Ultimate Addons iPhone charger and case. I don't have an iPhone. I do have a desire/need to charge via USB though. Sadly, I don't have time to wait for shipping so I was wondering if anyone might point me in the direction of finding any of these:
USB connector: PREFERRED
http://www.amazon.com/gp/product/B00...A2E944XTTK6JT6
These two would work too (need to charge both micro and mini)
Micro USB:
Mini USB connector:
Alternatively, these can't be too hard to make... A standard USB female connected to a Hella Super seal that plugs into the already wired-in system on the bike...
Ideas? I'll be in ANC on Monday and possibly FBX Thursday. Thanks in advance!
The road of excess leads to the palace of wisdom
-- William Blake
A witty saying proves nothing
-- Voltaire
Madmardigan is offline   Reply With Quote
Old 06-15-2013, 05:43 PM   #2
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,400
http://www.alaskaleatheronline.com/s...Adapter/Detail
Tom S is offline   Reply With Quote
Old 06-15-2013, 05:55 PM   #3
Madmardigan OP
Oddometer: 128
Not quite...
I wish that would work... The connecter is the Hella super seal, not the SAE...
If I could find some of these, I might be willing to wire it up myself. Just chop a USB cable, terminate with these:
http://www.kramp.com/shop-de/en/1140...seal+Hella+SET
Thanks though!
-- William Blake
-- Voltaire
Old 06-15-2013, 06:10 PM   #4
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,400
I know zip about any of these connectors.
No SAE connector for a battery tender on the bike? You should go to AK Leather while here in any case.
Old 06-15-2013, 06:54 PM   #5
Fast Idle
Since the Sixties
Fast Idle's Avatar
Oddometer: 309
Alaska Leather and Frigid North, both on Spenard. Between the two places you'll find what you need.
2002 R1150 GS
74 R90/6- Restored
69 Triumph Daytona 500- Survivor
1970 Honda SL100
- Survivor
Riding as much as my old frame will allow!
Fast Idle is offline   Reply With Quote
Old 06-15-2013, 08:25 PM   #6
Madmardigan OP
Oddometer: 128
Thanks! I was planning on popping in AK Leather - always try when I'm in the state. Will try Frigid North too. Appreciate the help!
-- William Blake
-- Voltaire
Old 06-16-2013, 12:56 AM   #7
AKmud
Muddy Gruver
AKmud's Avatar
Oddometer: 944
There should be an OEM connector near the left rear of the saddle. I've seen some hard wired with a mounting bracket, and others just tie-wrapped and stowed. You might take a look there first to see if it is equipped with one.
AKmud is offline   Reply With Quote
Old 06-16-2013, 01:01 AM   #8
AKmud
Muddy Gruver
AKmud's Avatar
Oddometer: 944
This is what I've been using for the last four years with zero issues.
Straight fused battery connection to a female cigarette lighter receptacle then a triple tap with two USB ports built in. Works like a charm.
Old 06-16-2013, 12:29 PM   #9
Madmardigan OP
Oddometer: 128
That's a nice setup, AKMud... I may look into something like that in the future. I do have the OEM plug, but I also have the "Ultimate Addons" iPhone system wired directly to the battery (I just bought this bike - it's how it came). That system has those Hella plugs that you can pop off the iPhone charger end and pop in a USB end. Just can't find their USB version in time... I think I'm just going to cut the iPhone cable and wire in a USB female as a work-around. Thanks for the tip though!
-- William Blake
-- Voltaire
Times are GMT -7.   It's 09:27 PM.
