Old 06-16-2013, 07:08 PM   #1
g.mccormick OP
g.mccormick's Avatar
Oddometer: 149
Where to start
I have a garmin 60csx that I bought used. It has city navigator loaded on it. I have only every use the unit by putting in an address and having it route me there. I am planing on doing some riding in the UP of michigan and hope to follow some tracks that others have created. I don't have any idea where to even start with this. What do I need to do to be able to build tracks and/or load others prebuild tracks?
g.mccormick is offline   Reply With Quote
Old 06-16-2013, 07:41 PM   #2
XRman
XRman's Avatar
Oddometer: 2,884
Basecamp
Download the free Basecamp program from the Garmin website.
Play with that a while and consult the tutorials on how that works on this thread ( see the sticky at the top of the page @ DRZ charlies thread)
what you will need to do is learn how to create a route to where you want to go on the BC map using waypoints like a bread crumb trail, then send that to your GPS unit using the appropriate commands on the BC program. You have to have a connecting lead from your PC- to your GPS machine to do this.
OK then go and follow your route on the bike. Then you can send your actual track file back to BC and keep a record of where you went for future reference or to share with friends.
Thats is about it. GPS 101 done!
XRman is online now   Reply With Quote
Old 06-16-2013, 08:04 PM   #3
Countdown
Oddometer: 5,618
You need either MapSource or BaseCamp but since you are starting from zero, BaseCamp is best choice.
With either one you can download other peoples Tracks from the internet and then download them to your 60. You can also hand draw tracks and download them to the 60.
The above post is all about Routes but you said Tracks. You do not need any way points to make/use Tracks.
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-17-2013, 08:07 AM   #4
g.mccormick OP
Oddometer: 149
Thanks guys. With Basecamp, it will use the map that is already loaded on the 60 correct? I don't have a disk.
Routes vs tracks-- i thought routes were what I am use to with turn-turn navigations, and tracks are bread crumbs. Which is better for offroad type riding? Will routes try and take me on highway?
Old 06-17-2013, 09:48 AM   #5
Countdown
Oddometer: 5,618
Yes BC will read the loaded CN, MapSoiurde won't.
99% of off highway riders use tracks.
Turn by turn is great at speed on highways with street names but not necessary on jeep roads and trails, just follow the Track.
You don't have time to watch screen and read instructions off highway. With Tracks and good maps just ride, when you come to an intersection just glace down to see which way to turn or to go straight.
Jerry Counts
Old 06-17-2013, 11:14 AM   #6
g.mccormick OP
Oddometer: 149
Will the basecamp allow me to load a new map? I am planning on hopefully following Cannonshot's Upper Penisula Adventure Trail (UPAT-1250) http://www.advrider.com/forums/showthread.php?t=627424
He states that using the maps from vvmapping.com is better than city navigator or topo. If I bought the vvmapping.com maps, would I be able to load that using Basecamp? Would i need a second card to load that map onto?
Thanks for the help.
Old 06-17-2013, 05:20 PM   #7
mcnut
Oddometer: 1,375
I think you need MapInstall, also free from Garmin, or MapSource (no longer updated/supported but available).
Bruce
mcnut is offline   Reply With Quote
Old 06-17-2013, 05:28 PM   #8
Countdown
Oddometer: 5,618
I assume Cannonshot provides Tracks for the ride. With good tracks you really don't need a map showing the roads & trails. You may miss a few turns especially forks in trail but you will see it quick if you keep zoomed in.
Jerry Counts
Old 06-17-2013, 06:10 PM   #9
250senuf
250senuf's Avatar
Oddometer: 2,379
The map on the card will be overwritten. Buy another card.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 06-17-2013, 07:39 PM   #10
thebugslayer
thebugslayer's Avatar
Oddometer: 61
I downloaded some tracks for a multi day ride (http://www.advrider.com/forums/showthread.php?t=632804) but when I view them in my gps (montana) I see only a short segment at a time. I expected to see the whole loop (as it appears in the map window in basecamp)which I could then just follow.
I am a total gps noob so can someone school me on this?
2007 r1200s
2008 wr250r
2009 dorsoduro
thebugslayer is offline   Reply With Quote
Old 06-17-2013, 08:27 PM   #11
mcnut
Oddometer: 1,375
You may be trying to load tracks which contain to many points, the 60Cx has a 500 point max per saved track, 20 saved tracks max.
You can;
Using MapSource of BasrCamp devide the tracks into 500 point segments.
or
Using MS or BC filter the tracks to 500 points max.
or
Using IMG2GPX create a transparent map overlay will all the tracks showing.
or
Buy a new GPS (78 or Montana) which can handle far larger and many more tracks.
or
Bring a laptop and load the tracks as you need them.
Bruce
Old 06-17-2013, 08:59 PM   #12
Countdown
Oddometer: 5,618
Sorry I can't find a .gpx file in the report. I think your Montana limits saved tracks to 2,000 points. If the file has more points you will need to filter them.
Jerry Counts
Old 06-17-2013, 10:51 PM   #13
mcnut
Oddometer: 1,375
Never mind my post, I didn't notice it was not from the OPer (who owns a 60Cx)
I know next to noting about the Montana other then it can handle an incredible number of tracks made up of a huge number of points.
Bruce
Old 06-18-2013, 03:06 AM   #14
thebugslayer
Oddometer: 61
Thanks Jerry. Is "filtering" a manual process of removing some of the "points" that make up the "tracks" or is it a function in basecamp or the montana software? I'm trying to figure out how to do this.
thanks for your help.
2007 r1200s
2008 wr250r
2009 dorsoduro
Old 06-18-2013, 11:10 AM   #15
mcnut
Oddometer: 1,375
The Montana does 10,000 point tracks and 200 saved tracks.
Hard to believe you need to filter any supplied.
Yes filtering tracks is an easy function in MapSource and BaseCamp and on most GPS units. The filtering has settings but the automatic with ??? max points works very well. Better then by time or by distance.
The result will be a track with maybe 10-25% of the points but still having 75-90% of the important detail, works well.
Bruce
HTML code is Off
Times are GMT -7.   It's 02:49 AM.
