Old 06-17-2013, 05:56 AM   #1
Hipster OP
Hipster's Avatar
Oddometer: 1,793
Lambda Sensor Heater Failure
How common is a heater failure in the Lambda sensor? My bike is flashing error code 18, indicating the front cylinder lambda heater has failed.
I found a used sensor on ebay but, if they fail from time to time maybe I should just buy a new one?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 06-17-2013, 06:05 AM   #2
RiderVic
KTM Konvert
RiderVic's Avatar
Oddometer: 23
FI error code
You may want to check the routing of the wire harness from the sensor to the connector. My dealer had assembled my 2012 990 with the rear sensor wire sandwiched between the frame and the crash bar clamp. This eventually caused an error code which was solved by rerouting the wire.
Current Ride '12 KTM 990 Adventure
RiderVic is offline   Reply With Quote
Old 06-17-2013, 06:17 AM   #3
Hipster OP
Hipster's Avatar
Oddometer: 1,793
This is the front cylinder sensor, wiring is fine.
Old 06-18-2013, 12:18 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,916
I had both sensors faulty after 35k kms.
Error code was heater grounded on both. I replaced them with used ones. I wonder if there are aftermarket replacements out there. I believe there are, but the difficulty is to match the electrical plug.
Cheers.
Old 06-24-2013, 05:56 AM   #5
Hipster OP
Hipster's Avatar
Oddometer: 1,793
I found an aftermarket oxygen sensor for KTM's, it's NGK p/n 28025. It's available on ebay for $100.
Old 01-11-2014, 12:54 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,916
Replacement lanbda sensors
http://www.lambdasensor.co.uk/main/n...tem=OZA591-VB2
supposed to be direct fit for Superduke
NGK Oxygen Sensor 28025 by NGK
OZA591-VB2 here :
Any Bosch alternatives?
http://www.magnumtuning.com/en/detai...nsor-installed
gefr screwed with this post 01-11-2014 at 01:26 AM
Old 01-11-2014, 10:23 PM   #7
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 501
howzabout $55?
Amazon has one listed for the 990 for $55 plus $5 shipping. I would check with Bosch's cross reference to confirm part numbers, just to be safe. My local auto parts shop will sell me Bosch O2 sensors for the same price, so I have just gone to them so far (BMW oilheads previously).
J.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo is offline   Reply With Quote
Old 01-12-2014, 01:29 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,916
I believe the $55 would come without the plug. This is what makes them cheaper. The sensor itself seems to be quite similar.
Cheers.
Old 01-13-2014, 01:53 PM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,916
I found the old OEM ones.
They have writing on them: NTK-JAPAN OZA591-VB2 7L16
not sure for the 7.
Cheers.
Times are GMT -7.   It's 08:43 PM.
