Old 06-22-2013, 06:36 PM   #16
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,546
Thumb
Success.
And those are good how-to photos.
--Bill
'73 R60/5 Toaster
Old 06-22-2013, 08:10 PM   #17
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
I hope that 6 hours included time to block the crank ?
Glad it's fixed.
Nice job on letting folks know what not to do. Let's call it the school of loud knocks...
Kai Ju is offline   Reply With Quote
Old 06-22-2013, 10:03 PM   #18
TINK OP
Oddometer: 733
Oh ya, we blocked that crank, using the Kai Ju method.
Glad it's fixed.
TINK is offline   Reply With Quote
Old 06-22-2013, 10:08 PM   #19
TINK OP
Oddometer: 733
Oil Pressures
Here's the oil pressure readings with the correct oil pump cover o-ring.
psi @ rpm - temp
120 @ 1500 - cold
90 @ 1000 - cold
130 @ 4000 - cold
60 @ 1000 - warm
70 @ 1300 - warm
90 @ 3000 - warm
95 @ 4000 - hot
35~38 @ 1000 - hot
TINK
Old 06-22-2013, 10:14 PM   #20
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
Yeah baby, Park Tool to the rescue.
Those look like good pressures, how did the filter look?
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 06-22-2013, 11:44 PM   #21
TINK OP
Oddometer: 733
Filter comes out tomorrow... stay tuned.
Old 06-24-2013, 07:54 AM   #22
_cy_
Oddometer: 6,437
congrats on the fix!!!
with clear no way to mistake pic's, the best kind.
Old 06-24-2013, 09:38 AM   #23
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
Thanks for the shout out and the great pic.
Old 06-24-2013, 09:57 PM   #24
TINK OP
Oddometer: 733
oil filter clean
Good news, the oil filter is clean, no bearing flakes.
We're good to go!
TINK
Old 06-24-2013, 10:43 PM   #25
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
We're good to go!
TINK
This is one of those rare events where a lesson is learned the hard way but inexpensively. Good for you.
So I can expect to see you riding the bike to work every now and then ?
Old 06-25-2013, 04:23 AM   #26
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
Happy for you!
Old 06-25-2013, 05:32 AM   #27
jackd
Oddometer: 3,071
Good to hear that your filter examination went well - I had a similar experience during my early airhead ownership as well. I would strongly suggest that you make a plan of doing some repeat inspections on your filter for the next time period and onwards. This is what we do on aircraft engines when we suspect there might be issues with the lubrication system (metal contamination, etc.) After a few of these re-inspects and nothing adverse appears, we all breath easy and declare the original issue has disappeared.
Old 06-25-2013, 05:59 AM   #28
Bill Harris
Oddometer: 8,546
I do the same thing-- "read" the filter frequently. Never see anything, but that is good news. I also am a firm believer in a magnetic drain plug for the engine. I typically get a small amount of very fine material (much less and much finer than the transmission), which is good. If I start getting larger amounts, that will be a warning to look at the cam chain or the cam/tappets or rocker arms.
Tink came out well because he handled this well. He caught the low oil pressure in time and took corrective action quickly. I doubt there is any engine damage because there is a vast difference between LOW and NO oil pressure. And hundreds of people are aware of this pesky o-ring quirk, so it's a win-win.
--Bill
'73 R60/5 Toaster
Bill Harris screwed with this post 06-25-2013 at 01:37 PM
Old 06-25-2013, 10:46 AM   #29
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 4,120
That is a beautiful bike you built there Tink. Glad the fix was cheap and (relatively ) easy. My favorite kind!
Big Bamboo is offline   Reply With Quote
Old 06-25-2013, 07:00 PM   #30
kaput13
kaput13's Avatar
Oddometer: 565
We're good to go!
TINK
Most excellent.
kaput13 is offline   Reply With Quote
Times are GMT -7.   It's 11:14 PM.
