Old 06-17-2013, 08:04 AM   #1
KaytM OP
Just a fella.
KaytM's Avatar
Oddometer: 202
Quickie question...
I just bought an '08 ADV rear shock off ebay for the very reasonable price of 70.
The spring on my '06 is rusty as ya like, which considering it's WP I find quite disappointing/annoying.
My question to the wise is can I do a straight swap?
(...probably should of asked before I bought it... )
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 06-17-2013, 08:07 AM   #2
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,072
Two questions:
What is the shock going on (different years and models had different suspension heights)
What is the spring rate of one shock vs. the other.
You asked a good question but did not provide the key information needed to answer it, like asking which color should I choose with out telling us what the choices are, of course we all know Orange in the right answer.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 06-17-2013, 08:13 AM   #3
KaytM OP
Just a fella.
KaytM's Avatar
Oddometer: 202
Thank you.
The shock going on is from a 2008 990 ADV, (http://www.ebay.co.uk/itm/2309800400...84.m1439.l2649), and my bike '06 990 ADV has the standard shock on it.
Where can I find answers to the great spring rate question please?? Does the pic help, thats from the '08?
(orange is the right answer unless your talking about your white power spring in which case white is the answer. ;) )
KaytM screwed with this post 06-17-2013 at 08:19 AM Reason: added pic.
Old 06-17-2013, 08:17 AM   #4
Tancakar
Tancakar's Avatar
Oddometer: 370
For a seven years old suspension what you were actually asking for? Suspensions are some thing always in use so if it rusty it might be the conditions but again 7 years old suspension if its even have no problem you should service it or change it.
Tancakar is offline   Reply With Quote
Old 06-17-2013, 08:30 AM   #5
KaytM OP
Just a fella.
KaytM's Avatar
Oddometer: 202
Basically I'm asking for a coat of paint thick enough to resist corrosion. ;)
Old 06-18-2013, 11:04 AM   #6
DSM8
DSM8's Avatar
Oddometer: 4,072
Originally Posted by KaytM View Post
Thank you.
The number on the two springs should be the same, that is the rate.
What is it thats corroding, the spring intself?
If so you can use something called POR on the spring it is what your looking for to prevent rust etc.
Old 06-19-2013, 03:40 AM   #7
KaytM OP
Just a fella.
KaytM's Avatar
Oddometer: 202
Eh?
Thanks DSM8.
I'm planning a 20,000 mile ride next year so I'm going to rebuild the bike over the winter replacing bearings and bushings, changing all nuts and bolts for stainless and waterproofing the electrics.
I'll be able to do a full on comparison then.
I'm quite sure I could get the 70 price I paid for the shock back but having a spare is also OK assuming it fits.
Has any one tried one of these shock sock things for keeping corrosion away from the spring?
MY bike has spent the last winter and a half outside and it's showing it, I think in future it would be as cheap to put it in storage over winter than to replace all the nuts and bolts that have turned KTM orange.
Old 06-19-2013, 01:28 PM   #8
DSM8
DSM8's Avatar
Oddometer: 4,072
Thanks DSM8.
Ok some things to think about before you go swapping all the bolts.
Note the number on the head of the bolts you want to swap 8.8, 10.2 etc that is the grade of bolt.
Not all bolts are created equal and stainless is not as strong as a 10.8 for example. So if your thinking about changing bolts that are structural in application might want to think twice.
There are coating you can put on metal to help inhibit corrosion. If you sprayed down the shock and then put the sock on it to keep the debris off the shock it might help.
Also make sure to use Anti-seize on every stainless bolt you use that goes in to AL to help prevent galling. I just use it on everything and torque accordingly.
http://www.engineeringtoolbox.com/st...es-d_1428.html
This one shows the stainless vs steel differences
http://k-tbolt.com/bolt_chart.html
Times are GMT -7.   It's 08:35 PM.
