Old 06-17-2013, 05:03 PM   #1
Baja Designs OP
Baja Designs
Baja Designs's Avatar
Oddometer: 600
Triumph Tiger 800XC Lighting Kit!!!
Hey Guys
Just wanted to show you our lighting options for the Triumph Tiger 800XC
This complete kit allows for the Baja Designs Squadron 3" x 3" LED lights to be properly mounted onto a 2013 Triumph Tiger 800XC with zero modifications. Purchasing this kit will provide you with every necessary component for a complete installation (no other purchase is necessary).
Our Squadron 3” x 3” light is the next generation of LED lighting! This kit packs 8,600 Lumens that will truly annihilate the night. The Squadron exceeds HID output yet weighs only 12oz. Uses active Thermal Management, Single Layer Solid Core Copper Circuit Board and aircraft grade aluminum housing that maintains LED temperature within the defined operating limits. If you’re looking for the ultimate in LED lighting technology the Baja Designs Squadron is your answer!
This kit includes everything you'll need for complete installation:
- Baja Designs Squadron LED Lights (x2)
- Bike Specific Mounting Hardware
- Baja Designs Relay Harness
- Baja Designs Rear Harness w/fuse
- High Beam By-Pass Extension Wire Set
- Thumb switch w/bracket
Features: For Each Squadron
Weight: 12oz
IP69K Certified (Submersible to 9ft)
IK10 Compliant (Mechanical Impact Testing)
Vibration Rating: 7.7Grms
Operating Temperature: -40 Celsius to +80 Celsius
Hard coated polycarbonate lens
Lifetime Warranty
Specifications: For Each Squadron
Total Lumens: 4300
Stainless steel fasteners and mounts.
Front Lens: Hard coated Polycarbonate
Power Consumption: 42 watts
Uses four T6 Bin Cree XM-L2 LEDs at 5000K
49,930 hour LED life expectancy
Specifications: For Each SII
Total Lumens: 2160
Power Consumption: 21 watts
The Squadron Kit
http://www.bajadesigns.com/ProductDe...mNumber=498003
The SII Kit
http://www.bajadesigns.com/ProductDe...mNumber=488003
Mike
mike@bajadesigns.com
www.bajadesigns.com
1-800-422-5292 ext. 114
-Bailey
Baja Designs is offline   Reply With Quote
Old 06-18-2013, 10:12 AM   #2
Baja Designs OP
Baja Designs
Oddometer: 600
www.bajadesigns.com
-Bailey
Old 06-18-2013, 10:27 AM   #3
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,670
That's an awesome kit. I use BD lighting on other bikes, and if my XC didn't already have the Triumph aux lights, I'd be all over this.
Thanks to BD for producing a specific kit for the XC. I hope you sell a ton of them.
Old 06-18-2013, 10:30 AM   #4
Baja Designs OP
Baja Designs
Oddometer: 600
Thanks for the post and support
www.bajadesigns.com
-Bailey
Old 02-06-2015, 04:25 AM   #5
Xpect8r
Xpect8r's Avatar
Oddometer: 65
I've been admiring the Baja Designs S2 Pros. I was thinking about using your "Contact Us" page, but I found this thread and thought there might be others with similar questions.
The photos on your website are a little hard to make out, and don't show the S2s. Do you have any photos of the mounting brackets, mounted on the Tiger 800, with the S2s? It looks like a very well designed bracket!
Is it possible to mix and match the pair? Is it possible to order one Driving Combo and one Wide Cornering?
Are the lights dimmable?
Xpect8r is offline   Reply With Quote
Old 02-06-2015, 08:59 AM   #6
Baja Designs OP
Baja Designs
Oddometer: 600
We do not have any photos of the S2 Pro mounted on that bike.
The photos on Our Website show the Squadron Pro for demonstration purposes. They would be mounted in the exact same location.
It is possible to order a Driving/Combo and Wide Cornering light in the kit.
We can also include a Wide Cornering Lens for you to do the swap yourself. That way you can always go back to Driving/Combo for both of the lights. Our U-Service technology allows you to swap the lens in less than 5 minutes.
Send me a message and I will happily answer any questions you have.
www.bajadesigns.com
-Bailey
Times are GMT -7.   It's 01:42 AM.
