Old 06-17-2013, 08:41 PM   #1
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Big tire issue
Well guys i had these mounted at my local shop its a Michelin Pilot Road 3 rear and Michelin Anakee 3 Front. Tires only have about 1200 miles on them when my better half pointed out these bulges on the rear and from the start the front has always sort of bounced (its been balanced and wheel is true and round). The front only "bounces" below about 40mph it smooths out going faster than that.
Any ideas as to what could cause this? I was told by Michelin to take them to my nearest dealer so i'll be going in tomorrow hoping for a warranty.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 06-17-2013, 08:55 PM   #2
oldxr
oldxr's Avatar
Oddometer: 1,151
I have a street bike that I have used on dirt but the reality is that the street bike tire casings are thin for performance(less weight = quicker turn in) and fearing damage I bought a dual sport bike.I wouldnt be surprised if the pr3 used the same casing as the pilot power-just different rubber compound.Your bike looks dirty like you went somewhere good.You might want to investigate some more off road style tires with more rugged casings.Having a tire blow on the freeway due to off road damage would not be good.
oldxr is offline   Reply With Quote
Old 06-17-2013, 09:01 PM   #3
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Been rocking the karroo tires offroad...these barely even saw a few graded gravel roads on my way to work maybe 1-2 a month.
Old 06-18-2013, 08:55 AM   #4
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,389
My first guess would be a sharp blow, like hitting the edge of a pot hole or some kind of road hazard.
Unsafe. Get Michelin to warranty.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 06-18-2013, 09:03 AM   #5
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,998
My first instinct tell sme that the beads were torn during mounting. Air migrates into the carcass when rubber is removed from the bead area, and I'd bet that is what has happened here.
Be certain that the shop that removes the tires for inspection does no more damage to the beads. Ask to be there when they're pulled off, and take pics.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 06-18-2013, 09:05 AM   #6
Mobiker
Mobiker's Avatar
Oddometer: 1,824
In a car tire, a sidewall bulge is usually a broken belt. Don't ride it anywhere. As motomantra says its not safe.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 06-18-2013, 09:23 AM   #7
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Sounds good. It'll be at the dealer tonight.
Times are GMT -7.   It's 09:30 AM.
