Old 06-19-2013, 01:12 AM   #1
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
99 XT600 Severe popping under acceleration
Last couple rides the bike has been popping severely through the carbs, starts around 3500 rpm and up and is getting worse, it pops five or six times each time I start getting on the gas and with each pop it momentarily kills the power, not like a fuel starvation bog but requires gearing down to get up hills, no popping on decelartion, bike starts and idles perfect, valve clearances are all up to spec, plug looks fine, compression is 159, fuel flow is good, I'm thinking it might be electrical since I dismantled/cleaned the carbs only 2500km ago when I installed a new top end. my question is if it's electrical which is the most likely part to cause this ? don't have a lot of cash so I'd really like to get it right, any suggestions are welcomed and appreciated !
Pursang is offline   Reply With Quote
Old 06-19-2013, 04:44 AM   #2
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,233
Plug Cap? or CDI unit?
BIG ED XT FAN is offline   Reply With Quote
Old 06-20-2013, 04:24 AM   #3
damo2010
damo
damo2010's Avatar
Oddometer: 413
I know u prob checked this, do u have a lge breather out top of the carb and is it routed correctly. This hose kills mid range revs similar to what your talking about
Damo
Yamaha Tenere XTZ660 4UX
http://share.findmespot.com/shared/f...rbiW8y1XLQCMtY
damo2010 is offline   Reply With Quote
Old 06-20-2013, 09:42 PM   #4
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Plug caps looks good, not sure yet about the CDI still looking into it.
Old 06-20-2013, 09:45 PM   #5
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Yup if you mean the hose from the secondary diaphragm to atmosphere it's clean and tucked away in a safe place under the seat.
Old 06-22-2013, 05:26 AM   #6
thumpthumpthump
Thumpthumpthump
Oddometer: 209
Is the choke all the way off? thumpthump
thumpthumpthump is offline   Reply With Quote
Old 06-24-2013, 08:45 PM   #7
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
I'm pretty sure it is, the bike starts, idles and runs perfect except for this popping which starts at about 3500 rpm.
Old 06-24-2013, 08:46 PM   #8
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Well the search is back on, I pulled the carbs and gave them a thorough cleaning, inspected every part except the coasting enricher and didn't notice anything obvious in the secondary carb, threw the bike back together and went for a short snort only 5 minutes into it the bike was popping like crazy, it seems to be getting worse with each ride cause on the previous ride it took half an hour to begin popping this bad, I'm wondering if it's an electrical issue ? would appreciate any suggestions.
I noticed the carb was sucking unfiltered air and discovered the original hose clamps even when bottomed out were not clamping tight enough, didn't take much effort to pull the rubber boot off the carb, will use another style of clamp that tightens more.
Old 06-30-2013, 04:19 PM   #9
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
To eliminate a few more possible problems I drained the fuel tank/carb, pulled both of the fuel petcocks off the tank, removed the screen tubes and blew everything clean with compressed air, the screens were surprisingly clean and the tank only had a few grains of sand inside, refilled with fresh premium and installed another spark plug, hit the magic button and no spark now I'm wondering if this issue is related to the original popping under acceleration problem ? any and all help would be appreciated with what to do next !
Old 07-14-2013, 01:44 PM   #10
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Here are the results of some testing with an Ohm meter. I would appreciate any suggestions as to what to check out next, should I have the Ignitor checked out if I can find a service that does that ?
Ignition coil, primary: 4.5 (spec is 4)
Ignition coil, secondary: 14.0 (spec is 13)
Stator coil: 0.6 (spec is 0.65)
Pickup coil: 243 (spec is 230)
Sparkplug cap: 00.0 (spec is 10k)
Sparkplug wire: 00.0 (spec ?)
Old 07-14-2013, 08:45 PM   #11
damo2010
damo
damo2010's Avatar
Oddometer: 413
Do you have spark back yet?
I've been told that the high voltage stuff can be problematic, not sure if you have changed any of the spark plug leads and cap.
From one of your previous posts, seemed like the popping was starting once bike was warmed up, maybe elec connections are getting worse with heat.
I'm no expert with this side of it, but maybe sounds like week spark?
Damo
Old 07-18-2013, 09:59 PM   #12
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Nope no spark at all, I tried another plug wire and cap from a set of automotive wires I had in the shop, they don't have the copper wire like the original but still I thought it would do if the plug wire/cap were the problem, still no spark.
Old 07-19-2013, 02:40 PM   #13
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,736
Automotive stuff will likely have a higher resistance, which is no bueno on that ignition system.
Would start simple; test output from stator first then work your way up to the coil to see where the electricity stops at. Like most big bore singles, the Yamaha singles did have CDI issues (black boxes get hot, then boil themselves basically).
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 08-12-2013, 11:32 PM   #14
Pursang OP
Bultaco !!!!!!!!!
Pursang's Avatar
Oddometer: 107
Thanks motomike, can you explain the procedure for checking for juice to the coil ? I set my tester to 200 AC and placed one of each lead to each of the wires going to the coil, turned the engine over but the meter remained at zero, I've searched all over for stator output procedures and numbers going to the coil but nothing is coming up, can't find anything in the various XT600 service manuals I have on pdf files either, I'm probably not testing it right.
Old 08-13-2013, 03:28 AM   #15
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 555
testing is done by resistance test
you can build a high voltage spark tester (i did once and it worked) but make sure it's a CDI, since it's a '99 it 's most likely a TCI sistem (uses lower voltage ) i think you can test it with 12 v (not sure)
As for the popping the 1990-2003 models have two pick-ups in the stator one for low RPM and one for high RPM
Check the harnesse where the high RPM pick-up connectes to the CDI
they can sometimes brake (as it kinks on a sharp turn ) where the wire goes in the plug
I think it's the blue wire
As for the HT wire to the plug , if you can remove it from the coil just connect a normal copper wire and connect to a spark plug to test output
more info :
http://www.transmic.net/en/home.htm
good luck
webmonstro screwed with this post 08-13-2013 at 03:34 AM
webmonstro is online now   Reply With Quote
Times are GMT -7.   It's 12:53 AM.
