Old 06-19-2013, 02:07 PM   #1
turdfergeson OP
Oddometer: 40
2013 990 Adventure Huge Oil Leak/Drain
About a mile from my house I noticed a ton of oil on the left side of the engine and all over my boot. My riding buddy said it just started and he actually got sprayed with oil and it was all over his front fairings and helmet face shield. This was after I just had the oil changed at a local shop and had about 150mi since the change.
Before I took the bike back in I cleaned up the mess and started/idled the bike for about 20 seconds to see where the leak was but couldn't pinpoint it. The best I could tell was it was somewhere on the front side of the front cylinder that faces the oil tank/radiator since that was where the bulk of the (remaining) oil was draining.
Shit like this doesn't bother me at, it's part of the game, what's killing me though is not knowing where the problem is.
Anyone ever run into this problem or have any ideas what the source/fix is?
2013 990 Adv Baja
turdfergeson screwed with this post 06-19-2013 at 02:08 PM Reason: 2013 990 Adventure Huge Oil Leak/Drain
turdfergeson is offline   Reply With Quote
Old 06-19-2013, 02:19 PM   #2
bajamcguide
Oddometer: 79
could be the breather hose or the hose from the top of the valve cover, could be the flow control valve that runs from the oil tank to the motor.
my bet would be the later as the gasket can be damaged if not properly installed.. I am sure it is something simple, and someone just missed something doing the service.. let us know what you find.HTH
RE. Tim
bajamcguide is offline   Reply With Quote
Old 06-19-2013, 02:23 PM   #3
turdfergeson OP
Oddometer: 40
Thanks Tim.
I'm expecting it be something stupid-simple like a hose which was why I was getting pissed when I just wasn't seeing anything like that. I'll definitely update the thread when I get an answer.
2013 990 Adv Baja
Old 07-10-2013, 12:40 AM   #4
turdfergeson OP
Oddometer: 40
The verdict was that the gasket highlighted in the pic blew out.
Old 07-11-2013, 09:32 PM   #5
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,042
Who did the last valve adjustment ?
Did you have to remove the motor from the frame to find this ?
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 07-12-2013, 02:01 AM   #6
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,779
Did they forget to replace the half moon seal? The rocker cover has an O ring seal which wouldnt have sprayed that much out over the motor.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-12-2013, 04:46 PM   #7
turdfergeson OP
Oddometer: 40
people=shit
MAXVERT -The motor in the pic is not mine, just one I found that clearly showed the seal. I haven't had any valve work done yet, I still have less than 3K miles on the bike.
I was surprised to find out that it only needed a little more that quart of oil put back into the tank so it still had over 50% left.
2013 990 Adv Baja
Old 07-19-2013, 01:08 PM   #8
turdfergeson OP
Oddometer: 40
RE. Tim
So I had the same seal blow out again and I checked the crankcase breather hose and it was not breathing. Mine is routed a little different because I gutted the stock airbox and replaced with the CPR Rottweiler and the valve is connected to the baseplate. I never really liked the idea of that venting into the airbox so disconnected the hose from the baseplate and attached a filter to the end. It's now been over 100 miles now and no problems.
2013 990 Adv Baja
Old 07-19-2013, 02:19 PM   #9
tacosupreme
tacosupreme's Avatar
Oddometer: 276
Was the hose kinked or something? Just curious, I'd like to do the CPR filter too and don't want to make the same mistake.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Times are GMT -7.   It's 01:09 PM.
