Old 06-20-2013, 09:42 AM   #1
tdvt OP
Oddometer: 217
Small bike, off-road, day-ride only GPS?
Sorry for yet another query, I have read multiple threads but I'm still looking for advice as most threads seem oriented to longer distance DS touring, multi-day rides, etc.
I don't have a GPS, haven't used a GPS (other than a borrowed Nuvi in the car once) & want to have something to track trail rides/explore others GPS tracks, off-road.
I don't plan to wire it to the bike (250 w/minimal electrics) at this point, so the power connector issue is not really a main concern & in the end don't really mind changing batteries, since I ride mostly day rides.
Montana is too much $$ & sounds like more than I need, so I've narrowed down (not knowing much) to either a Garmin 78 or an Oregon 450.
Suggestions/insights?
tdvt is offline   Reply With Quote
Old 06-20-2013, 09:58 AM   #2
250senuf
250senuf's Avatar
Oddometer: 2,407
The 78 will do fine.
Even an eTrex provided there is something better than the bicycle mount for it.
I'm not a fan of touch screens.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 06-20-2013, 10:15 AM   #3
Countdown
Oddometer: 5,693
Originally Posted by 250senuf View Post
the 78 will do fine.
Even an etrex provided there is something better than the bicycle mount for it.
+1
Jerry Counts
Countdown is online now   Reply With Quote
Old 06-20-2013, 10:52 AM   #4
travatron
Oddometer: 30
I'd agree with the 78. It's small and easy to use, and if you ever do decide to wire it up or put it on a bigger bike, you'll be ahead of the game.
travatron is offline   Reply With Quote
Old 06-20-2013, 10:54 AM   #5
EmmEff
Oddometer: 1,736
I've never used the 78, but I sure like my Oregon 450. I have no hesitations recommending one. GPS City had them on sale a few weeks back for $199. Can't beat that price, IMO.
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff is offline   Reply With Quote
Old 06-20-2013, 12:26 PM   #6
bkg123
Oddometer: 263
I have absolutely zero complaints with my Oregon 450. As EmmEff said, 199.00 is a pretty good price.
Brian
Tiger 800XC
bkg123 is offline   Reply With Quote
Old 06-20-2013, 01:13 PM   #7
tdvt OP
Oddometer: 217
Thanks for all your replies. Have to ponder the touch-screen vs. buttons thing. Screens seem fairly close in size which is a consideration for me.
Is the satellite acquisition pretty similar between them?
Old 06-20-2013, 02:07 PM   #8
250senuf
250senuf's Avatar
Oddometer: 2,407
Check the spec. 78 is patch antenna, don't know what the Oregon uses. Quadhelix is better.
Old 06-20-2013, 03:12 PM   #9
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,756
In some cases yes, in other cases no. It depends on the size of each antenna, the orientation of the antenna, and other factors. If you keep your GPS somewhat "flat", a patch antenna of "equivalent" size will usually perform better. Also, the sensitivity of the receiver circuitry has a major effect. Without knowing the size of each antenna, and the receiver sensitivity, and the way the unit is to be mounted on the bike, it’s hard to say which would be better, though I suspect both would be very good. I would think the touch screen issue might be a bigger deciding factor.
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 06-20-2013, 03:27 PM   #10
Countdown
Oddometer: 5,693
Does the antenna effect the accuracy of the lon/lat calculation or just the how much loss can be between the receiver and enough satellites? Loss would be pointing off main gain lobe, trees, building, water, etc
Jerry Counts
Old 06-20-2013, 03:54 PM   #11
bkg123
Oddometer: 263
I don't believe my Oregon is equipped with the retro-encabulator or the meso-helix modulator, but it has always been right where I am, and the touch screen works with gloves. The batteries last a long time, and in daylight you can turn the backlight off. It can get knocked around, and it picks up satellites in my living room (why I have satellites in my living room however, is a mystery).
Brian
Tiger 800XC
Old 06-20-2013, 05:08 PM   #12
250senuf
250senuf's Avatar
Oddometer: 2,407
Comparing a 78s (patch) and a 60cx (quadhelix) laid flat side by each the 60 got a better gps accuracy reading. 78s - 10m; 60cx - 3m. Traded spots - same result.
Sometime when both owners are at the same place with some time to try it, this "test" will be repeated.
Old 06-20-2013, 05:38 PM   #13
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 463
76cx
I've got a couple of Garmin 76cx GPS units.
Within a couple of minutes I commonly see 9 FOOT accuracy.
Close enough for me! ;-)
NorthernTraveler is offline   Reply With Quote
Old 06-20-2013, 05:45 PM   #14
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,756
Yes and no. The number of satellites that the unit "sees" affects accuracy (more sats = better accuracy) because the signals from each are somewhat averaged to reduce error. A better antenna might see more satellites.
Old 06-20-2013, 08:28 PM   #15
Countdown
Oddometer: 5,693
That is exactly what I thought. So in open desert with low horizion for 360 degrees no possible difference. Besides with old 76C could not even get postion in redwood forests on north coast so as long as my76Cx & 78 locks on, I am happy traveler.
Jerry Counts
HTML code is Off
Times are GMT -7.   It's 06:52 PM.
