Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 06-21-2013, 03:30 AM   #1
wibby OP
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,599
Headlight Modulator
Got pulled over today and issued a warning for Unlawful/fail use lights - Class D
811.520
Trooper told me to not use my modulator, and that it was unlawful as well as annoying
States right in the Oregon Motorcycle Manual that modulators are permitted
Wish me luck tomorrow
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 06-21-2013, 04:59 AM   #2
wibby OP
wibby's Avatar
Oddometer: 10,599
Crosshairs will really be on me now, just got done writing ​Lieutenant Douglas Ladd of the Roseburg Area Command
'05 DL650
'92 KDX200
Old 06-21-2013, 05:00 AM   #3
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,258
huzar is offline   Reply With Quote
Old 06-21-2013, 05:07 AM   #4
wibby OP
wibby's Avatar
Oddometer: 10,599
Did not know you washington fags had that much cool in you
'05 DL650
'92 KDX200
Old 06-21-2013, 05:09 AM   #5
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,258
Old 06-21-2013, 05:45 AM   #6
FLYING EYEBALL
out of step
FLYING EYEBALL's Avatar
Oddometer: 10,562
you washington fags
I'm not from here.
if you keep poor...the struggle is simple
my photos http://jskustoms.smugmug.com/
save yourself some $ with my smuggy discount code qvMaWy1bTFU7c
FLYING EYEBALL is offline   Reply With Quote
Old 06-21-2013, 06:17 AM   #7
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,394
n16ht5 is offline   Reply With Quote
Old 06-21-2013, 07:56 AM   #8
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,781
If you were using it at night you are hosed. Only daytime use is permitted.
However, it says nothing about using a disco ball... just sayin....
Mr. Fisherman is offline   Reply With Quote
Old 06-21-2013, 10:45 AM   #9
kwisn
One Happy Dog
kwisn's Avatar
Oddometer: 9,785
Freedom is about living your life freely, not living my life freely. HrtofAg What's your angle, bacon? Crocker
kwisn is offline   Reply With Quote
Old 06-21-2013, 10:53 AM   #10
Sedro Tom
No hurry, no worry
Sedro Tom's Avatar
Oddometer: 2,406
Ride while you can - ozo
Sedro Tom is offline   Reply With Quote
Old 06-21-2013, 11:58 AM   #11
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,258
I thought most modulators have a nighttime cutoff switch via a photoelectric diode, so they'd stop modulating after dark?
Old 06-21-2013, 12:41 PM   #12
Suva
57
Suva's Avatar
Oddometer: 200
811.520
Modulators are annoying. When bikes with them pass I end up staring at them, and just like a trail obstacle I end up steering right for them. If you want to be seen install large amber running lights.
Suva is offline   Reply With Quote
Old 06-21-2013, 02:47 PM   #13
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,344
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 06-21-2013, 03:06 PM   #14
pHelix
Eternal n00b
pHelix's Avatar
Oddometer: 1,265
They may be annoying but they're required in some states...
Kevin
We are not alone. There is ALWAYS someone downstream and downwind.
pHelix is offline   Reply With Quote
Old 06-21-2013, 03:23 PM   #15
Wlfman
Wlfman's Avatar
Oddometer: 1,290
Taken from http://www.oregon.gov/ODOT/DMV/pages...clecodebk.aspx
Oregon Vehicle Code (chapters 814 and 816)
814.320 Failure to display lighted headlights; exceptions; penalty.
(1) A person commits the offense of failure to display lighted headlights on a moped or motorcycle at all times, if the person operates a moped or motorcycle and does not display lights and illuminated devices specified under ORS 816.320 and 816.330 at all times the motorcycle or moped is upon a highway.
(2) A person may use modulating headlights described under ORS 816.050 during daylight without violating this section, but a person who uses such modulating headlights during limited visibility conditions is in violation of this section.
(3) This section does not apply when specific exceptions with respect to parked vehicles are made under ORS 811.525.
(4) A court may dismiss, without penalty, any charge for violation of this section if the court determines that:
(a) The violation was caused by a malfunction of equipment; and
(b) The equipment that malfunctioned and caused the violation has been repaired or replaced.
(5) The offense described in this section, failure to display lighted headlights on a moped or motorcycle at all times, is a Class B traffic violation.
REQUIREMENTS AND STANDARDS FOR SPECIFIC LIGHTS
816.050 Headlights; rules.
Each of the following is a requirement for headlights as described:
(1) On vehicles required to be equipped with two or more headlights under ORS 816.320 and 816.330 the headlights shall be equally distributed on each side of the front of the vehicle. This subsection does not apply to motorcycles and mopeds.
(2) Headlights shall show a continuously burning light except that:
(a) When permitted under ORS 814.320, headlights for motorcycles or mopeds may have an upper beam that can be modulated between a high and
lower brightness at a rate of 200 to 280 pulses per minute
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
