Old 06-22-2013, 01:59 PM   #1
olaham OP
Oddometer: 2
Adventure 990, high battery charging..
Hello Adventurer
I have recently purchased a KTM 990 Adventure 2007 and after one season with the bike i am very impressed with it so far. Much power and feels very robust. I have some reflections that i want to ventilate. I have noticed that the electrical charging is a bit high. At idle rew. the charging is ca 15,5 volt, it varies between 14,9-15,7 volt. Anyone experienced something similar? I have no problem with the electrical but the battery was bad when i bought it so i got a new battery from the shop.
I think it runs a bit hot also, the fan kicks in quite fast when i drive slowly, just before the fifth bar lights up on the dash. It has no trouble holding the temperature down then so i ques it is as it should be.
The normal jerkyness with the injection is there but its normal from what i have read. One could ask for a better software from Keihin in my opinion but it is probably not that simple.
I would be grateful for some experiences from other owners if we share some of the things i have noticed with the bike.
Thanks Ola from Sweden.
olaham is offline   Reply With Quote
Old 06-22-2013, 06:54 PM   #2
renogeorge
Oddometer: 1,394
You can check the stator output voltage ahead of the voltage regulator. If it is good there problem is regulator. If high there, problem is stator.
I would also check all ground connections.
Good luck
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-22-2013, 07:52 PM   #3
Motomedic
Motomedic's Avatar
Oddometer: 2,497
If the bike is OVERcharging, the stator's doing it's job, but the regulator isn't. If you're really seeing voltages over 15vdc (using a quality voltmeter?), better replace the regulator before you toast another battery. Normal charging voltage is between 14 and 14.5
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 06-23-2013, 02:07 AM   #4
Katoom72
Katoom72's Avatar
Oddometer: 897
14-15 @ 5k RPM
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Times are GMT -7.   It's 02:44 PM.
