Old 06-23-2013, 07:00 AM   #1
blaster11 OP
Ding fries are done!
blaster11's Avatar
Oddometer: 6,922
Adventurization of my Husqvarna TE511
So the adventurization of my TE511 begins. Some say that the bike is just a dirt bike with tags....they may be right but I think it can be more....way more. So as I build it I will post the updates and changes...the good, bad, and the ugly of the build and the shortcomings of the bike if any. So what's my goal.....Minimum 200 mile fuel range, comfortable seat, and able to haul my camping gear and miscellaneous other stuff for up to a short multi week adventure. I am sure I will have more requirements as I really sit down and work through the details but these will do for a start.
Check back to this post regularly as this is where I will post updates to my plan and also which post you can go to for each upgrade.
First upgrade is the pegs or should I say peg extensions. Since my foot is still pretty screwed up from last years incident I figured that a large platform on which to stand would be a good investment. So I got a hold of Zip Ty racing and placed an order for their peg extensions, they seem to be a leader in aftermarket parts for the Husky.
These should make life pretty good!
So if you remember back a couple of years ago Bill Conger, an instructor from the BMW off road school, attempted Dakar but it didn't work out so well. In the process of the build of his TE449 he did quite a few things which I thought were pretty good so I took note and waited for the day I got my own TE.
One of the things I worry about is that Husky parts may become difficult to locate or that what little aftermarket there is may dry up so some parts may be purchased first just so that when they dry up I already have them, which is the case with my next part. An adapter for an external oil cooler from Zip Ty racing.
Upgrade #2, the way I figure it cooler oil is happy oil, to a certain point, and more volume is good as well...especially for the long hauls, so I bought the part that I thought may be hard to come by and the more generic parts, i.e., oil cooler and lines, I will pick up a bit latter as time and $$ permit. The bonus is that the kit comes with a reusable filter so if you are out somewhere and flood the bike out, filter replacement won't be an issue, just change the oil and clean filter and carry on. Pretty nice piece!
blaster11 screwed with this post 06-23-2013 at 07:54 AM
blaster11 is offline   Reply With Quote
Old 06-23-2013, 07:29 AM   #2
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Wicked Heated grips
Since this bike on a good day only has about 165 watts of available power of which probably 1/2 or more of that is needed to run the bike. I realized that since I wouldn't be able to run a heated jacket liner, what was next most important thing to keep warm....that would have to be my hands. So I found a guy in the flea market selling a set of heated grips which should make life a bit nicer when the cooler temps roll around....I will install them later this year.
Old 06-24-2013, 07:01 AM   #3
markusarealuis
markusarealuis's Avatar
Oddometer: 102
Oil cooler...
Man that oil cooler looks like a killer gatling gun!
I really can't wait to watch this thing develop!!
2007 Triumph Tiger
markusarealuis is offline   Reply With Quote
Old 06-25-2013, 12:55 PM   #4
markusarealuis
Oddometer: 102
Potential Rack
I think you should add one of these to your adventure bike.
2007 Triumph Tiger
Old 06-25-2013, 05:40 PM   #5
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Looks pretty nice, who makes it and how does it mount?
Old 06-25-2013, 05:47 PM   #6
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Auto retraction no more!
So the latest is to fix the auto retracting side stand. At first I found it entertaining but it quickly became irritating so with a quick spin of the Dremel with a cutoff wheel I removed the nub which makes it auto retract....back to a normal kick stand.
Sorry I didn't get a picture while it was still attached.
All good now!
Old 06-25-2013, 06:06 PM   #7
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Power up!
So one of the other things which is not only really irritating but also dangerous as hell is the problem known as "Flameouts". As I understand it it is due to an extremely lean fuel mixture which allows them to get past emissions but it stalls out at inopportune times, like pulling out in traffic.
So take off the seat and then you will see the computer which is held on with two rubber insulators, one on each side. Use a suitable tool and free the computer from the isolators.
Under the computer you will find two plugs, the smaller one is the one needed for the power up function.
Remove the cap and you will find two open pins, sorry I didn't get the picture without the jumper. I tried first with multi conductor wire but it kept fraying and was too big as well. I had a few pieces of solid conductor phone wire laying around so I made a short jumper and installed it.
I then reinstalled the original cap and put the connectors back where I found them and reinstalled the computer back from where it came.
This it what it looks like now on the odometer, it's hard to read but the screen says "Race map II" after installing the jumper. This should richen up the mixture a bit and stop the "flameouts"....hopefully. I haven't had a chance to ride it yet.
Old 06-26-2013, 06:25 AM   #8
markusarealuis
Oddometer: 102
fantastic write up
This was very helpful!! I did pull that last night and there is definitely not a "jumper" wire in mine. Also, have you ridden your bike since the "jumper" was installed? I have never experienced the "flameout" problem, and mine runs pretty smooth. Although it does lack any significant power.
2007 Triumph Tiger
Old 06-26-2013, 09:45 AM   #9
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Thanks...I am glad you found it helpful!!! I haven't had time to ride it yet as I have been pretty busy. Apparently the jumper along with removing the Cat makes a pretty significant improvement besides not burning your leg off just sitting still. If I get time this week the plan is to decat it as well.
Old 06-26-2013, 01:47 PM   #10
LukasM
Oddometer: 5,418
How long have you had the TE for, and how many miles of dual sporting have you done on it?
Unlike it's big brother 610/630, the smaller Huskies are all known for their notoriously narrow gearboxes which suck for mixed slow and fast riding...
Old 06-26-2013, 03:12 PM   #11
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
About 2 months now and probably close to 500 miles of dual sporting. Definitely close ratio on the gearbox which has taken some getting used to. Actually my biggest complaint other than the seat is how twitchy the throttle is, I find it hard to regulate it as it is either on or off which is making it hard for me to be smooth on the trails.
Old 06-26-2013, 04:17 PM   #12
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,670
Thumb Reprogram ECU
Since you know about the pegs from Zipty, I assume you know about his ECU reflash service for $40.00.
http://www.ziptyracing.com/te449-511-ecu-upgrade/
You can call me TKO
tokyoklahoma is offline   Reply With Quote
Old 06-26-2013, 04:35 PM   #13
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
That is high on the list right now but my DRZ is down so I thought I would wait a bit so I wasn't without a bike. The ECU reflash seems like the way to unleash the bike along with the decat.
Old 06-26-2013, 05:19 PM   #14
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,687
One of the best mods that I did on my ktm was a tool box built into the skid plate. I'll be making another for my Husky when I get a chance. Something to think about if you want to do week+ trips.
dirtydeeds is offline   Reply With Quote
Old 06-26-2013, 05:24 PM   #15
blaster11 OP
blaster11's Avatar
Oddometer: 6,922
Good thought, I will keep that in mind.
Times are GMT -7.   It's 06:38 AM.
