Old 06-23-2013, 01:19 PM   #1
Paulie OP
Paulie's Avatar
Oddometer: 314
Question "follow road" route problem
I'm trying to use a route made on google maps on my 76cx, in "follow road" mode. Damned if the gps always wants to go into "calculate" mode & screws up the route.
I've used this that & the other conversion programs for input, a whole bunch of em. Pretty slick stuff, I gotta say! Have also tried all the diff "follow road" settings on the gps. Mapsource or basecamp, same dang result. Groan.
If ya got any decent clues, lemme know...thanks.
Paulie is online now   Reply With Quote
Old 06-23-2013, 04:31 PM   #2
250senuf
250senuf's Avatar
Oddometer: 2,381
Make it into a track or several. 500 point limit per each of max 10 tracks.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 06-23-2013, 06:15 PM   #3
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 462
Tracks on 76cx
500 points max on each of 20 tracks.
Also, WinGDB will convert it for you to tracks with LOTS of points, which you then filter down to 500 points each.
This is the best way I've found to do it...
NorthernTraveler is offline   Reply With Quote
Old 06-23-2013, 06:17 PM   #4
250senuf
250senuf's Avatar
Oddometer: 2,381
Oops, thanks for the correction.
Old 06-24-2013, 03:10 AM   #5
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,128
What maps are loaded on your GPS? I'm guessing your roads don't match between the two.
First recalculate in Mapsource or Basecamp, and then load into your GPS after ensuring the map data is the same (if using Mapsource).
dunno.....
Old 06-24-2013, 03:45 AM   #6
Paulie OP
Paulie's Avatar
Oddometer: 314
They're both City Navigator NA NT 08, which seems to be ok. Yeah, I've tried that recalc in M - B & it also gets wacked out. Doing it on a lil local 5 mi route that's EZ to test, before a 7-8k ride in August.
Old 06-24-2013, 05:30 AM   #7
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,597
That's the problem with many of the handheld units. You're really not doing anything wrong, it will ALWAYS recalculate the route and it will ALWAYS change it unless you are very careful of where you place your via points. You're also limited to 50 of those so you're stuck with some very short routes if you get complex with the routing. Like others have suggested stick with tracks as the 76 is pretty much a useless routing GPS.
Old 06-24-2013, 07:44 AM   #8
wbbnm
wbbnm's Avatar
Oddometer: 2,188
If you really want to use routes you should do lots of practice runs like you are planning. You will find lots of problems that can generally be overcome with proper GPS unit settings and route planning.
Or not.
I would definitely recommend creating tracks as a backup in case routing just doesn't work out.
wbbnm is offline   Reply With Quote
Old 06-24-2013, 08:21 AM   #9
Countdown
Oddometer: 5,632
+1 No Brainer
Jerry Counts
Countdown is online now   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 11:44 AM.
