Old 06-25-2013, 08:29 AM   #1
icebergstu OP
Husqvarna Tragic
icebergstu's Avatar
Oddometer: 490
Removal of old stickers from plastic tank help
How?
Especially how without scratching the plastic?
And if plastic is scratched will it buff back with a good soft woolen pad?
Stu
Husqvarna TE610 Adv
Husqvarna WR 300 2T
Honda CT110
icebergstu is offline   Reply With Quote
Old 06-25-2013, 09:06 AM   #2
Scootern29
Scootern29's Avatar
Oddometer: 494
I've had good success with a heat gun to soften the stickers and use lacquer thinner to remove the glue residue.
Scootern29 is offline   Reply With Quote
Old 06-25-2013, 09:15 AM   #3
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
WD-40
Kinda looks like you try'd it already.
Spray it on,let it sit alittle,then try it.
The wifes hair dry'r does help.For some reason they get all pissy bout it,but it'll help.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 06-25-2013, 09:37 AM   #4
KZJohn
KZJohn's Avatar
Oddometer: 333
I use a heat gun each time I change the graphics on my bikes. I then use WD-40 to remove the glue residue then wipe that off with some contact cleaner on a shop towel. If you need to scrape them off, use a plastic wedge, it won't damage the plastic under the sticker.
1976 KZ900A4
1985 CR250R
2006 CRF450X(Baja ready baby!!)
Team Hammernutrition/T&S Motorsports
KZJohn is offline   Reply With Quote
Old 06-25-2013, 10:16 AM   #5
Twin-shocker
Oddometer: 1,673
Looks like your stickers have been applied, then clear lacquer over the top. See if you can remove lacquer with paint thinners, then use a heat gun to get stickers off. Stickers never work that well on plastic tanks, as the tanks are porous and the stickers generally start to bubble pretty quickly.
Old 06-25-2013, 10:43 AM   #6
icebergstu OP
Husqvarna Tragic
icebergstu's Avatar
Oddometer: 490
Ok...as I dont have heat gun, the Mrs hair dryer will have fo cut it. Might make a shed run after she goes to bed.
Cheers for the advice. Let you know how it went.
Stu
Husqvarna TE610 Adv
Husqvarna WR 300 2T
Honda CT110
Times are GMT -7.   It's 08:29 PM.
