Old 09-03-2014, 05:26 AM   #151
mike54
You don't get me
mike54's Avatar
Oddometer: 13,222
Looking for rear turn signal mounts for a 92 R100GS.
Part # 63 23 1 244 020
Thanks.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 09-28-2014, 06:50 AM   #152
knucks
Oddometer: 186
Looking for the grab rail for my r75 seat. Seen some on eBay for $100+, looking to spend much less..
knucks is offline   Reply With Quote
Old 09-28-2014, 08:32 AM   #153
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,513
The /5 grab rail is the same if later models. The first year had a funny two piece that will also work. Max BMW lists this part still available for $211.
---Albert Einstein
Old 09-28-2014, 10:38 AM   #154
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 973
Getting a seat rail isn't quite as easy as it sounds. First, you need to determine which seat you have. If you have a 1970 or 1971, it will be a short wheel base seat with two separate grab rails, the wrap around hand rail will not work on these seats (period).
If you have a 1972 seat, this is a short wheel base seat but the first year of the wrap around seat rail. A long wheel base seat rail can be made to work on a short wheel base seat (if a short wheel base seat rail is unavailable) by mounting the two front mounts first then bending the rear mounts to meet the seat.
If you have a 1973 seat, this could be both a long wheel base or a short wheel base seat (you will need to determine which you have). Again, this would be the wrap around seat rail. A short seat rail will not work on a long seat.
On both the 1972 and 1973 seats (long or short) the two individual hand rails of the 1970 and 1971 seats will not work. The hand rails need to be matched to the proper seat pan.
On 1972 and 1973 seats (and some later seats) the common replacement was a Reynolds back rest.
Pokie is offline   Reply With Quote
Old 10-13-2014, 05:35 AM   #155
Capt. REDBEARD
TWECO
Capt. REDBEARD's Avatar
Oddometer: 1,126
were is the best place to go for used airhead parts? I am looking for a forum like this where I can post WTB ads. IBMWR?, BMWMOA? Pelican? All of them? easier to say which to avoid/are a waste of time?
I appreciate the input.
WTB:
1976 R60/6 speedo/odo/tach instrument cluster cover. the one with the indicator light and glass bezels.
1976 R60/6 seat latch assembly. I have a good working tumbler - I just need the latch assembly. or some advice on how to fix my assembly. the back plate is pushed out/deformed (I am assuming from prolonged pressure from the spring mechanism) and basically functions as it should other then it not holding the seat closed TIGHT. it holds the seat - but there is a lot of slop and play - is this normal??
1976 R60/6, 2009 530 EXC, 2008 250 XC, 2004 950 ADV
if the ocean were whiskey and I were a duck - I'd swim to the bottom and never come up
Capt. REDBEARD is offline   Reply With Quote
Old 10-21-2014, 04:50 AM   #156
therealbatman
"Godfather"
therealbatman's Avatar
Oddometer: 409
WTB FRAME 87'-95' GS or 91'-95' R100R frame with title
A friend is looking for a titled frame for a project he is working on.
He needs a 1987 - 1995 GS frame or a 1991 - 1995 R100R frame. Must have a title.
Please PM me if you can help.
TIA
1978 BMW R100/7
2008 Wee Strom
therealbatman is offline   Reply With Quote
Old 10-21-2014, 02:42 PM   #157
strichzwei
Oddometer: 28
Hi, I have an R80ST frame, which is exactly the same as the R80G/S - not exactly what you are looking for but start of a great project - with title!
PM if interested.
Scott
TIA
strichzwei is offline   Reply With Quote
Old 10-21-2014, 03:07 PM   #158
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,900
PM if interested.
Scott
Scott, the frame is slightly different as the G/S and ST run a different wiring harness and the spaces to connect the relays etc. on the frame are different.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-24-2014, 05:46 AM   #159
acap650
acap650
acap650's Avatar
Oddometer: 681
In the past year I've worked on an '84 ST, an '85 G/S and an '81 G/S. The '84 ST and '85 G/S both had a relay bracket welded to the top tube, the '81 G/S did not. Also the ST and G/S have different footpegs so the rider peg bracket may also be different. That is all I have to say about this.
acap650 is online now   Reply With Quote
Old 10-24-2014, 10:59 AM   #160
DiabloADV
Semi-Occasional
Oddometer: 2,305
Who makes this rack? And...do those bottom tangs bolt to the passenger peg holes?
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 10-24-2014, 12:37 PM   #161
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,623
Originally Posted by DiabloADV View Post
Who makes this rack? And...do those bottom tangs bolt to the passenger peg holess?
Krauser mount from the /5 era. Note of caution; if you think removing the rear wheel is a pain in the butt, with this mount, forget it! To mount or remove this rack you will need to remove the taillight and turn signals. These can be made for short or long wheelbase models, be sure to get the one specific to your model. The tangs bolt to the holes in the muffler brackets. Passenger pegs are unaffected.
Big Bamboo is offline   Reply With Quote
Old 10-24-2014, 12:48 PM   #162
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,513
I have those on my /6. To remove the rear wheel I take the front wheel off, tie the centerstand to the crossover pipe or the front axle, that has been replaced, and tip the bikes rear up and rest the bike on the front forks, rear end elevated. Now the rear wheel will come out thru the bottom.
Piece of cake.
---Albert Einstein
Old 10-24-2014, 12:59 PM   #163
strichzwei
Oddometer: 28
foot peg brackets are exactly the same.
Scott
Old 10-24-2014, 01:32 PM   #164
DiabloADV
Semi-Occasional
Oddometer: 2,305
Thanks for the tips. It's for sale locally. I'm not going to buy it now, but it's $100 if anyone is interested.
Old 10-31-2014, 09:33 AM   #165
TDL028
man of leisure
TDL028's Avatar
Oddometer: 357
how much would this front end go for? Id sell the forks, triples, wheel, and tire all together. no fender or headlight assembly. basically unbolt the triples and fender then sell. has a metzler with alot of meat left on it..
Dgr! by TDL028, on Flickr
My '84 R80 overhaul:
http://www.advrider.com/forums/showt...errerid=297067
Frame Hoops: Gasolineheaven.etsy.com
Instagram: too_many_projects
Gasoline_Heaven
TDL028 is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
