Old 06-26-2013, 05:36 PM   #1
c-zulu OP
Resident Dirt Burner
c-zulu's Avatar
Oddometer: 1,313
Balance shaft seal removal..
What tools are used or required? for you guys who have done this already..
Please and thank you..
Current Rides:
HONDA CRF450X---BUELL XB12X
KTM 950 SER---KTM 950 ADV S---KTM 690 ER
MOTO GUZZI STELVIO NTX---VICTORY KINGPIN TOUR
c-zulu is offline   Reply With Quote
Old 06-26-2013, 06:48 PM   #2
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,401
Easy, basic sockets 10mm IIRC.
I got pix somewhere. The big magnet needs some coaxing off.
Mine was smoking a lot, new seal did the trick
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 06-26-2013, 06:54 PM   #3
Orangecicle
Orangecicle's Avatar
Oddometer: 2,451
No special tools. You remove the cover, lay it on the ground, and use something to pry out the old seal. Mine was pretty tight in the case. I used a screwdriver with a little block of wood under it to keep from denting the aluminum cover. Bang the new one in place, and you are good to go.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 06-26-2013, 07:41 PM   #4
c-zulu OP
c-zulu's Avatar
Oddometer: 1,313
Will do, thanks
Current Rides:
Old 06-27-2013, 11:46 AM   #5
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,270
C-Zulu, how's she running now? Are you still scaring the Minnesota skeeters away with your KTM 950 2 stroke?
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 06-27-2013, 12:56 PM   #6
c-zulu OP
c-zulu's Avatar
Oddometer: 1,313
Test run today and no blue smoke.
Current Rides:
Old 07-01-2013, 08:59 PM   #7
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
As I've just discovered, you can thread a coarse 9/16 bolt in through the center of the old seal, and it jacks it right out. That's after I got scared using a screwdriver and went looking for something less destructive.
erappaport is offline   Reply With Quote
Old 07-02-2013, 11:09 AM   #8
Peanuts
Peanuts's Avatar
Oddometer: 1,565
An open ended wrench can be used to pry out an oil seal.
Peanuts is offline   Reply With Quote
Old 07-02-2013, 01:36 PM   #9
dmn0507
dmn0507's Avatar
Oddometer: 350
NExt time i'll give it a try.
I had luck with a very pointy center punch and hitting the seal a few times around (tapping towards the center) then it came right out
dmn0507 is offline   Reply With Quote
Old 07-03-2013, 08:20 AM   #10
950TRANSALP
950TRANSALP's Avatar
Oddometer: 794
brittle
Man at 50,000 miles my seal was brittle and came out in little square bits .
No wonder it was smoking , totally fixed the problem .
Screwdriver out deep well socket in and fixed .
Thank heavens for ADVrider trouble shooting ! ! !
"The more you drive the less intelligent you are !"
Repo Man - 1984
950TRANSALP is offline   Reply With Quote
Old 07-03-2013, 08:36 AM   #11
DirtyADV
DirtyADV's Avatar
Oddometer: 2,189
From when I recently replaced mine.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 09-23-2013, 08:15 PM   #12
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 443
A picture tells a thousand words! Well, quite a few anyway. Now I know where that seal lives. Going to do it next week as preventative at 15000km.
Getting quite a list of PM items now...Stat, cap, WP, oil press sw, gear posn sensor O ring. About an extra couple of hours work every valve check. Not a big deal.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Times are GMT -7.   It's 01:03 PM.
