Old 06-26-2013, 06:27 PM   #1
pascal toureasy OP
Oddometer: 8
ECU "locked" at factory?
Yo OC inmates-
Went to my local dealer to have the Akrapovic map installed this weekend to match my sexy new cans.... The tech explained he was unable to load the new map, and the service manager followed up yesterday saying that KTM says my factory settings are "locked" and my ECU needs to be sent to KTM to be flashed and then it can accept the Akrapovic map.
I know my purchasing dealer in NorCal had previously changed the maps for me (not the akra) without issue. New dealer says the Akra map adds beau coup at the low end, less at the high side, which is good by me...
Anyone else experienced this phenomenon? Appreciate the shared wisdom
Cheers,
Pascal
When the going gets weird, the weird turn pro...
pascal toureasy is offline   Reply With Quote
Old 06-26-2013, 07:22 PM   #2
DuctTape
Oddometer: 351
What year?
Sounds more like what you have to do if you own an Aprilia and don't have a Navigator.
Time to download Tune ECU, buy or build a cable and be done with the Stealership.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 06-26-2013, 07:45 PM   #3
alongat
alongat's Avatar
Oddometer: 1,216
First time I have heard of this on a KTM. Are you confident in your dealer's abilities? Is this dealer prepared to temporarily swap your ECU with another bike to double-check? Sounds like their KTM diag tool may be at fault...
Originally Posted by pascal toureasy View Post
Yo OC inmates-
Cheers,
Pascal
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 06-27-2013, 03:53 AM   #4
pascal toureasy OP
Oddometer: 8
It's a 2008.....and its my first encounter with the dealership and they do not carry the KTM road line....so no other bike to swap the ECU
Need to do some recon on the tune boy....
Old 06-27-2013, 04:07 AM   #5
NKL
Oddometer: 189
If the previous map was changed by TuneBoy then yes the ECU will be locked to TuneBoy only I believe, but that is not anything to do with KTM.
NKL is offline   Reply With Quote
Old 06-27-2013, 11:26 AM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,953
If the bike is an 08 go the Tuneboy route, that way you can be in control of your own fate and make changes as needed to the map when ever you wanted.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 06-27-2013, 02:03 PM   #7
NKL
Oddometer: 189
And have a lot less money in your pocket, TuneECU would my preference, it's free.
Old 06-27-2013, 02:26 PM   #8
DSM8
DSM8's Avatar
Oddometer: 3,953
Either one works (I did not dig into the details) I just know both will allow the user the ability to load and modify the fuel maps.
Old 06-27-2013, 04:59 PM   #9
pascal toureasy OP
Oddometer: 8
Talked to my mechanic in Santa Cruz this afternoon, says the St. Louis dealer is incorrect..no lock, no flash required.
I'll attribute the situation to inexperience on behalf of the new shop...
Old 06-28-2013, 01:49 PM   #10
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 665
Sometimes stealers give you an answer to make you go away so they don't have to tell you the truth... Like the fact that they probably did not know how to load the ECU map or that their diag tool is borked or some such unspeakable offense. DIY man, you'll get better results!
kaptinkaos is offline   Reply With Quote
Times are GMT -7.   It's 10:38 AM.
