Old 01-01-2014, 12:17 PM   #31
guglemonster
Oddometer: 294
Eh?
Originally Posted by Themastermike View Post
Those gains seat of the pants or dyno?
Sent using Telepathy
Here again we are talking the wrong language
I do not talk about more power just better response
Pants if you want, pants of people working on rally sets, but it was a by product of the free of standard filter design
I went for getting rid of the original dwarf design and obtained also a better responding bike
More I am not saying nor selling ;)
Ain't no wonder trick, it 's a filter setup nothing more
Again every time somebody is talking about something simple and cheap which works there must be a dyno run ;)
I just wanted clean petrol whatever the source without having to put and remove filters at cap o putting original mini filters
guglemonster is offline   Reply With Quote
Old 01-01-2014, 01:40 PM   #32
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 777
Never said MUST, just asked if verified.
KTM engineers know about flow requirements even if they don't consider the guy on the road and plugged filters.
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 01-01-2014, 02:33 PM   #33
guglemonster
Oddometer: 294
Heheh
Here another issue which I personally find very interesting
Engineers
Yep there must be some working at Ktm, but I suppose they drive the fork lifts
Air box
Regulator
Clutch master/slave
Clutch push rod
Generator
Main switch and fuse position
Battery size/position
Fuel pump assembly
Brake lines for abs bikes
Pds
The list may get a tad boring so I'll stop here
Ktm is far from being a perfect product, I am pretty fond of mine but have being working at it since 2007 and I am still wondering what will come next
About the fuel...
Let,s take the gs 1200 or any previous 11xx ie model
Ever took apart the pump in tank set??
Weeeeeeel far from perfect but much better designed an the newer Kim jimmick
Big strainer, automotive std fuel pump, general in line in tank alu fuel filter,
The new 1200 has not a set up were you must wait until all goes clogged up and you must change filter and pump !!!!!!!! Again marketing haahahaha
Got a solution for that too.... Just as somebody already did also here ;););)
What Ktm was after was a copy-proof system to tie the customer to original spare parts
First prefilter is/was plastic based membrane water separating and prone to sudden clogging and pump cavitating origin
The paper filter has the size good for a carburetor 125cc Jawa not a fuel gouged like our small virgin
No... Ktm eng have nothing to do with thi part of the bike.... Believe me
Here is marketing people after the cash for the original spare and consumables were they charge you a 100 bucks for 5$ stuff
And please don't tell me it's a fair price or I will put in the 40€ they charge for two stupid o-rings
Btw. The new per filter lost water separation capacity gained 30% more surface filtration and is now based on non woven PE wool trapped in a 200micron mesh
Btw
The same filter is used on the er6n..... Sort of a bad joke no??????
Now any one interested in revealing his profession as a Ktm eng??? Nope even if they do check all important forums.... Or at least they should haahahaha
I was Piaggio product marketing...... Was there bought the ticket got the scars
Ps
Damn I hate thi friggin istupidpad it's continuously changing or erasing what I'm writing
guglemonster screwed with this post 01-01-2014 at 02:40 PM
Old 01-01-2014, 03:15 PM   #34
Themastermike
Passin gas
Oddometer: 777
Marketing.
You are good with words.
Old 01-01-2014, 03:33 PM   #35
Hootowl
Oddometer: 1,259
Not listed as a fit for 950/990's but maybe its modifiable
http://www.cyclebuy.com/shopping/splitstream/index.htm
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 01-01-2014, 05:01 PM   #36
renogeorge
Oddometer: 1,389
Thanks. I think that will work for me. Maybe get one and modify it so it fits and can be moved to each tank when filling. I have 3 tanks with in line filters for the right side and auxiliary. Should work for a mexico trip and infrequent fill ups from questionable sources....
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-01-2014, 08:59 PM   #37
RoundOz
Plenty of seasoning
Oddometer: 1,023
Yes
Profill (Australia) makes slip-in tank filters for Safaris. I reported this here:
http://www.advrider.com/forums/showt...errerid=129859
Originally Posted by LocuL View Post
anyone done anything with the Aqualines/safaris?
http://www.motocrossworld.com/site/s...oduct_id=33834
2009 KTM Adventure
RoundOz is online now   Reply With Quote
Old 01-01-2014, 11:24 PM   #38
guglemonster
Oddometer: 294
Marketing.
Ups do I have to feel offended???
I am better with my brain and hands
Ok, how should I demonstrate the results behind the words????
Pictures???
My solution to pump filter with reusable automotive prefilter and multiple water stopping layers media replaceable ????
How to fix an out of th tank automotive filter and remove the stupid paper umbrella???
My solution for below the cap mounting filter???
You see, it's a forum, people talk, people work, people solve ;);)
It' a wonderful think tank over e world, there are plenty of other forum with great people presenting ideas and working on their bikes, and I am happily part of some very fine ones among them and it's my luck ;);)
For the ret jut brain squeezing and good old sweat and research
Ups... Again just words haahahahah
As for the rest of filters you are presenting
All can be adapted, it's only a question on how you think e problem over and if they will or will not solve the problem of the dumb filter set at pump
Old 01-02-2014, 04:17 AM   #39
renogeorge
Oddometer: 1,389
I am enjoying your enthusiasm for the whole discussion. But I am confused as to exactly what you are recommending and selling?
I saw the earlier pictures of the in-cap sock type filters. Do these fit original KTM Adventure gas caps? Can I assume they are easily removable for cleaning? What is price?
It also sounds like you have an idea for a different solution at the pump? What is it you are recommending? Automotive type cannister filter? Where? How? Pictures??
KTMs--300, 518, 990
Old 01-02-2014, 04:38 AM   #40
guglemonster
Oddometer: 294
Shah
Thank you for your words
I asked the admin if I can put my stuff and how
Don't want to go against any rules and don't know hot to post otherwise both my ideas and the results
I do produce under the caps filter, to clean them, should ever the need arise since they are really big compared to the pump prefilter for example, you simply remove the cap and clean them, or in case of the separate membrane you open the cap and remove/clean and remount it :)
As for the pump solution I produce a multy layer filter twice the sice of the original one just to mount on the pump instead of the tea bag
For the paper filter I have simply installed outside the tank an in-line GM or Bosch automotive filter, petrol reinforced hose and inbox screw bracelets (not sure about the translation)
https://www.google.com.tw/search?q=f...p-zZUjDWIYM%3A
Sorry for the link don't know how to post it with e iPad
As for the "socks" they are designed to be attached under the fuel cap and stop any contaminants, two type, for carburetor bikes 20/30 microns high speed flow and for ie bikes 0 microns filtration.
Maybe in order not to break any rules I should wait for the admin ;)
As for your trip to Mexico, I will send you a couple of ideas in mp waiting for the admin :)
guglemonster screwed with this post 01-02-2014 at 05:12 AM
Old 01-02-2014, 05:11 AM   #41
guglemonster
Oddometer: 294
Forgot to answer
Eh eh
My enthusiasm derives from many years of passionate mounting and dismounting plus an infinite passion for mechanics bikes and home made solutions e heheh
As from the filter
GM or BOSCH (MANN is also great bu too expensive)
I positioned it on the left side of the air box against the frame
This was Before fixing it simply between air box and frame
Another solution is a Mazda filter, but at 50$ the original one I preferred Bosch at 20$ with straight joint
But the Mazda would be ideal
Don't get the meat and doria after market version the filter media sucks too mic
To test media and filtration of all mi ideas I usually cut open and check everything before mounting and than I ride it getting the worst
Here the petro I got after washing one of my prepump filter after 10.000 km in Albania Macedonia Bulgaria and Rumania
Yes I am bloody paranoid haahahaha but I love my passion too much haahahaha
Regards
Old 01-05-2014, 10:25 AM   #42
alpheus
Italian Carrot
alpheus's Avatar
Oddometer: 80
Regards
Noooooooooooooooooooo ... :-)
alpheus is offline   Reply With Quote
Old 01-05-2014, 12:45 PM   #43
guglemonster
Oddometer: 294
ahahahhahah
finokkio ahahahha
ciao ragazzo come butta??
Old 01-06-2014, 08:30 AM   #44
alpheus
Italian Carrot
alpheus's Avatar
Oddometer: 80
Fuel filters installed in 990 filler caps.
ahahahhahah
finokkio ahahahha
Gayoooooo ... Puoi anche rispondere ai messaggi eh ... :-)
Ti sei ripreso????
Old 01-06-2014, 09:58 AM   #45
guglemonster
Oddometer: 294
cazzo.. che messaggi??
yep tutto bene, collo ancora mezzo bloccato ma sara' una cosa lunga :)
te?? fra??
Times are GMT -7.   It's 02:36 PM.
