Old 07-01-2013, 07:46 AM   #1
SpeedyR OP
SE in the SE
Oddometer: 907
SE dies sporadically - fuel pump? fuel line connector QR?
Did a big DS ride with some friends a few weeks ago. We ended up getting some gas out of my bike on a longer leg of the ride by unclipping the fuel line QR and pressing on the internal button so that we could pump some gas out of the tank. Hit the on/off button a few times, fuel pump pumped gas into our bottle and off we went.
riding to work last week, the bike started to run on one cylinder, then stopped all together. Pull into a side street and checked the fuel cap (new fuel cap) but no pressure release as I unscrewed it and plenty of fuel (8 gallon safari tank). I checked the fuel line connector and it looked like I never put it all the way back together. Pulled it apart (it wasn't fully seated), and plugged it back in till I heard/felt the click of it connecting, and it fired right up. off to work.
So riding yesterday, I had the same symptoms where it started to run on one cylinder for 100yards or so, then cut off completely. I pulled over, checked the connector and it was connected fine but I disconnected it and put it back together and it fired right up. Any ideas if these are the symptoms of a fuel pump going back or is there maybe just something I didn't get straight on the first time I connected it back on. Or do these connectors go back?
I rode maybe 50 miles or so between the time I put the connection back together correctly, and the second occurrence. After getting it running again, I rode about 30 miles of pavement, single track and some whoops/jumps/berms chasing a 9 year old around a small "track" on a 110. lol. No problems.
Bike is an 07 950 SE, just turned over 10k miles on the clock. safari tank with new gas cap (venting fine) and checked the fuel taps and everything is good there as well.
Thoughts?
SpeedyR is offline   Reply With Quote
Old 07-01-2013, 11:11 AM   #2
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
I doubt the disconection, reconnection the second time was the fix. Next time just shut off the bike and wait a minute. If it starts afterwards and ryns then it might be the pump starting to go. Then I would take a look at the points on the pump. If you havent replaced the pump before, you are due.
DeepInIt is offline   Reply With Quote
Old 07-01-2013, 11:20 AM   #3
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,968
My SE fuel pump points went bad around 10,000 miles. It will give you a warning like you mentioned . . . Then, it will not work at all. Get new points or Dr. Beans solid state unit.
Before and after 10,100 miles:
I changed the points on my SM at 8,000 miles (PM) . . . Looks like it had another 2K left in it. All the wear was on the top point:
mcmann screwed with this post 07-02-2013 at 12:06 PM
mcmann is online now   Reply With Quote
Old 07-01-2013, 11:48 AM   #4
JRod152
will work for tires
JRod152's Avatar
Oddometer: 347
Sounds FP related...
"My SE fuel pump points went bad around 10,000 miles. It will give you a warning like you mentioned . . . Then, it will not work at all. Get new points or Dr. Beans solid state unit."
...I agree. My vote is for the Dr. Beans upgrade. It's been very reliable for me so far. It's an easy fix and provides a lasting result.
Whatever you do, heed the warning you are getting before you get stuck in BFE.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 07-02-2013, 08:58 AM   #5
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
Buy a Dr Bean Kit. = Fuel Problems gone forever.
Yes the quick connect fitting can be a pain in the arse to reconnect.
The fuel pump is exactly the same pump on my Africa Twin., Plus its the same on a ZZR 600.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 07-02-2013, 10:03 AM   #6
renogeorge
Oddometer: 1,395
Or the Facet option....Ran one ion my 959 SM for 25k miles with zero problems.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 07-02-2013, 11:25 AM   #7
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,961
+1 on the DR Bean Kit.
Like it better than the Facet since it fits in stock location and no moving parts since it used an electronic eye.
Did that to mine when converted to carbs.
Best money ever spent.
Period
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 07-03-2013, 01:34 AM   #8
Mosseltje
Alive
Mosseltje's Avatar
Oddometer: 190
Had the same problems.
My fuelpump after 3.000 miles.
< KTM 950 Super Enduro| Husaberg FE570 | Honda CBX 1000 Z >
Mosseltje is offline   Reply With Quote
Old 07-03-2013, 04:34 AM   #9
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,631
Just looked for and found dr beans upgrade. http://www.lc8.nl/download/fuelpump%20manual.PDF
I think I have a spare Facet in my garage, ill have to check.
Jeff, I think my Adventure is due for the same thing. Running like crap this weekend, it kept wanting to stall ... Backfiring and the smell of fuel. Coming home down hwy60 from Two Wheels of Suches was not pleasant at all.
flux_capacitor screwed with this post 07-03-2013 at 04:41 AM
flux_capacitor is offline   Reply With Quote
Old 07-03-2013, 06:53 AM   #10
SpeedyR OP
SE in the SE
Oddometer: 907
Acme has new points in stock so i'm going to go that route for a temporary fix, then research a bit more into the Mikuni. It seems to be one option that has very few failures if you locate the pump in the right place and do the plumbing correctly.
my buddy steve also has a mikuni but hasn't mounted his yet either. That way we can carry a spare and share it between the two of us on rides. lol. :)
flux i'll keep you posted on outcome and what it looks like in the pump.
Old 07-03-2013, 01:10 PM   #11
blackness
more riding
blackness's Avatar
Oddometer: 115
What Hodgo said. The Dr Bean kit works.
While you are working on the bike might be worth giving the ignition switch a clean as well.
blackness is offline   Reply With Quote
Times are GMT -7.   It's 01:01 PM.
