Old 07-01-2013, 05:02 PM   #1
zedtours OP
zedtours's Avatar
Oddometer: 361
Clutch weirdness
Posted this query on UK KTM forum with no result. Fitted new clutch kit from KTM all plates and discs but now have to pull lever all the way in to disengage which makes feathering clutch almost impossible. There is no air in hydraulic system and with cover off I can see the plates being pushed all the way with the clutch lever. It has improved slightly in a couple of hundred miles. Is it just bedding in?
zedtours is offline   Reply With Quote
Old 07-02-2013, 06:58 PM   #2
renogeorge
Oddometer: 1,367
I always start with air in the hydraulic system. I takes so little air to reduce clutch push rod travel enough to impact disengagement. Beyond that possibly a mismatch between the new clutch pack and the push rod. I have heard of (but not experienced) a need for a different rod or shimming to get full disengagement.
Good luck
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 07-02-2013, 07:28 PM   #3
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,833
Make sure the clutch master cylinder is topped off. Very small capacity . . . If the level is down it will not engage fully etc.
Motorcycles . . . my Happy medicine.
Live to ride . . . ride to Live . . . just like breathing to Live . . .
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
mcmann is online now   Reply With Quote
Times are GMT -7.   It's 07:41 AM.
