Old 03-06-2014, 12:05 AM   #2296
markjenn
Oddometer: 10,473
Originally Posted by SchizzMan View Post
I'll also check to see if the new Lycoming A/C engines have O2 sensors.
In a general aviation piston engine? I'd guess we're about five decades from having such radical new technology. We're just now starting to get rid of magnetos.
Back to using avgas in a bike, as someone has already pointed out, there is a awfully high level of lead in avgas (even 100LL which is "low lead" only in comparison with the ridiculous amount of lead in earlier avgas). Even if poisoning the cat or O2 sensor is not a concern, that's still a lot of lead being ingested in an engine that is radically different in size and operating characteristics from a GA piston engine. (And lead-fouling is still a big issue in GA with 50-hr plug cleanings usually required to get rid of the lead deposits.) And then there is the usual debate about whether higher octane does any good in an engine not designed for it. Not to mention the $6.50/gal (in the US) prices. I wouldn't use it except in a pinch.
BTW, 100LL is actually about 96 octane if measured by the R+M/2 method used for US pump gas.
- Mark
markjenn screwed with this post 03-06-2014 at 12:23 AM
Old 03-06-2014, 12:29 AM   #2297
SkizzMan
There, that's it
SkizzMan's Avatar
Oddometer: 8,806
FADEC A/C engines have been out for many years using O2 sensors which have a compelling history of being done in by the lead in avgas.
So saith Google. Amen.
Good catch, marchyman.
"You don't take photos for yourself, you take them for the old man you will become - if you are lucky." - Falang
"As long as there's a horizon and I can see it, then I want to know what's there, mentally, physically and visually" - rtwpaul
SkizzMan is offline   Reply With Quote
Old 03-06-2014, 12:45 AM   #2298
IB1
IB1's Avatar
Oddometer: 1,026
- Mark
Piston engines are still used in general aviation. We've got some 2-seater piston engined planes used for training purposes. But everythiing else uses a turbine. Either turboprop or turbofan.
And the price isn't relevant here. For our regular fuel we pay around $8 a gallon in Europe.
But short conclusion. Don't use avgas in your bike, specially in a new GSA. You will ruin it.
Past bikes: 09 BMW F800ST
Current ride: 2013 BMW R1200GS
On order: 2015 BMW R1200GSA
Yes, still a rookie
IB1 is offline   Reply With Quote
Old 03-06-2014, 12:46 AM   #2299
markjenn
Oddometer: 10,473
For piston engines and certified (not experimental)? Color me skeptical.
- Mark
Old 03-06-2014, 12:50 AM   #2300
markjenn
Oddometer: 10,473
Not sure how wide a net you are casting with "we've got", but piston engines are still heavily used in general aviation for all but the upper end of the market - you can still buy new piston singles and twins with six-seats or so and turbines don't start penetrating the market until you get into corporate aviation with $2M+ pricetags.
- Mark
Old 03-06-2014, 03:58 AM   #2301
IB1
IB1's Avatar
Oddometer: 1,026
- Mark
In europe piston engines (in aircrafts) are normally only used for training or recreational purposes. I've worked some time on our mayor airport and we never had piston engines aircraft flying over. Since this is a heavily populated area lower cost/small distance transports are done via road, rail or water, so the low end air transport doesn't really exist here.
Our smallest aircafts are twin engine, 8 passenger luxury business jets for VIP transport.
Yes, still a rookie
Old 03-06-2014, 04:38 AM   #2302
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,192
Originally Posted by JimVonBaden View Post
I know for a fact that the 04-12 R1200 series have antiknock sensors, and am almost positive the new Wetheads also have them.
No WGS doesn't have.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 03-06-2014, 05:36 AM   #2303
smr238
Sam
smr238's Avatar
Oddometer: 146
Fadec is an acronym for full authority digital engine controll. It is used on newer turbine engines. I have never seen an o2 sensor on a turbine engine. There is no need. The more fuel you pour into a turbine the more power it produces. With out protection devices you could add fuel until the engine oversped or melted. I dont know if GA recips are using anythig that advanced or not.
Sam
smr238 is offline   Reply With Quote
Old 03-06-2014, 07:04 AM   #2304
Flying Tivo
Oddometer: 211
Diesel
Only the very few and new diesel engines use a FADEC.
Felipe
2013 1200GSW Brand Spanking New!
Flying Tivo is offline   Reply With Quote
Old 03-06-2014, 07:54 AM   #2305
asphaltsurfer1
CatManDoo
asphaltsurfer1's Avatar
Oddometer: 126
I'm going to avoid Avgas personally. Don't want to have that conversation with the dealer in event of warranty. I have 8 gallons at 43mpg on high oct and will only run low grade and corn when I have to. One reason for going GSA was being able to go further to be more selective on gas stop out West in places like NM.
I did run Shell racing fuel in an old Sportster once. The iron engine was designed for unleaded and as it was slowly removed from our supply I lost significant power and it ran way too hot. The racing gas didn't help horsepower any but sure made it run a lot smoother. I tried it on my Mille R several years ago and scared me with white smoke and gray exhaust. I would have thought it would have run better with it.
Staying with pure and simple highest octane gas when possible.
asphaltsurfer1 is offline   Reply With Quote
Old 03-06-2014, 04:48 PM   #2306
Uly
Oddometer: 43
Originally Posted by Joachim View Post
That sounds different to my issue. Mine will always catch on the second attempt instantly. I'm hoping for a software update maybe?
I've noticed the same thing on mine. I just figured they all do that
Uly is offline   Reply With Quote
Old 03-06-2014, 09:52 PM   #2307
SkizzMan
There, that's it
SkizzMan's Avatar
Oddometer: 8,806
If I'd known mentioning FADEC would take the thread to the topic of diesel I would never have brought it up. My apologies. But, yes, there are FADEC piston A/C engines that burn avgas. I think the only relevant points raised so far relate to leaded fuels compromising the cat and O2 sensors.
Moving on.......
Old 03-06-2014, 09:56 PM   #2308
pistole
Oddometer: 1,349
you aeroplane people need to get a room man !!
pistole is offline   Reply With Quote
Old 03-06-2014, 09:58 PM   #2309
SkizzMan
There, that's it
SkizzMan's Avatar
Oddometer: 8,806
I'd settle for a weekend of nice riding weather.
Old 03-07-2014, 02:07 AM   #2310
NLS
NLS's Avatar
Oddometer: 3,192
True. All this needed a separate topic (a split?).
(actually I was thinking of posting this yesterday, but then thought it could attract some hate, esp. since I don't own a WGSA, which seems to be a prerequisite for some to even have an opinion)
NLS
My Blog
Times are GMT -7.   It's 02:50 PM.
