Old 08-25-2013, 05:36 PM   #1
mass-klr OP
mass-klr's Avatar
Oddometer: 170
SW Motech center stand on KLR650
Anyone else having problem with instability of the sw centerstand? When I put my bike on the center stand the stand is at nearly 90 degrees. So I can't use the stand on a slite downhill or it wil run of the stand. I had a pretty bad experience today while changing my rear tire. Had bike on centerstand, changed tire, as I was putting the tire back on and trying to put the chain on before I had the axle installed I push the tire forward a bit and pushed the bike off of the center stand. You can just imagine what a mess that was when the bike fell over while the tire was not on yet. I had to get my neighbor help me get it back on the stand. I am very worried that something was damaged when the back of the bike fell on the tire/sprocket/brake rotor. Put everything back together and it seems to be ok. I would be very worried using it to change my tire alone somewhere using the center stand.
Any suggestions? Is it even worth having it?
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 08-26-2013, 09:56 PM   #2
Jtoper
Adventurerer
Jtoper's Avatar
Oddometer: 62
dremel it!
I had the same issue on my 2009 KLR. I had it on the center-stand at work when a co-worker bumped the back of it. That was enough to push it forward off of the center stand. Luckily, he is a big boy and was able to catch it and man handle the thing before it hit the ground.
How did I remedy the situation?
I took a dremel with a small stone wheel to the point where the pin sits against the mount:
Seems like SW-Motech would have dealt with this before putting them out to market. I guess they just figured they were going on a KLR so it would be ok.
You have to take out enough material to make the bike sit back on the stand a bit more and you won't have this problem again. The other option is to just go out and get one of these like I did.
The first option is a hell of alot cheaper though. Hope that helps and good luck.
Jtoper is offline   Reply With Quote
Old 08-28-2013, 05:59 AM   #3
Lowrider_Bud
I'll ride anything..
Lowrider_Bud's Avatar
Oddometer: 21
Use the front brake...
I don't have a centerstand, but do use a "jiffy-jack". When lifting the rear wheel I wrap a bungee cord around the front brake lever so it can't roll forward or backwards. Working on the front wheel I put the bike in gear. Pretty simle and works.
Lowrider_Bud is offline   Reply With Quote
Times are GMT -7.   It's 01:32 PM.
