Old 07-02-2013, 07:32 PM   #1
indr OP
Oddometer: 501
Throttle Sync
indr screwed with this post 02-22-2015 at 09:18 PM
indr is offline   Reply With Quote
Old 07-02-2013, 08:17 PM   #2
JimVonBaden
"Cool" Aid!
Oddometer: 53,263
From the info you gave, yes, or no, or both.
How about a year, make and model to give us a clue what you are looking to figure out?
Jim
Old 07-02-2013, 08:38 PM   #3
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,709
Not with my IR thermometer. Hi spec isn't high enough to take temps of headers, will just decalibrate it and then would have to wait 1/2 hr until it recalibrates and is useable again.
Expensive them IR thermometers that will read really high temps such as headers temps.
Have tools, will travel!
Old 07-02-2013, 10:09 PM   #4
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,709
You need some kind of vacuum balancer, there are a few out there. Not lending my old mercury filled for safety concerns.
Exhaust temps may work. Could be slow, takes a while for the pipes to show temperature changes. In any case and I looked it up recently 7-800F seems average but they can go much higher than that.I doubt you can fine tune anything that way but could be good enough all things considered.
I think you need expert help. I heard good from these guys:
http://motomethod.com/
Old 07-03-2013, 04:38 AM   #5
PeterW
Oddometer: 2,690
Harmonizer - see vendors.
Like hens teeth, but make this trivially easy.
Pete
PeterW is online now   Reply With Quote
Old 07-03-2013, 04:55 AM   #6
showkey
Oddometer: 1,955
Side note.......IR temp readings from a shiny surface are not accurate.
The rest questions have been answered, some sort of vacuum gauges is the preferred method for carb sync.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 07-03-2013, 05:35 AM   #7
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,318
First I've ever heard of doing it that way
Just get a vacuum balancer. Morgan Carbtunes are the best, IMHO.
Don't bother trying to make your own -- all that stuff on the Ninja 250 forums about homemade systems is a waste of time and materials -- they never work well enough to get a decent result.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 07-03-2013, 09:31 AM   #8
ericrat
Oddometer: 1,211
Taking the header temp would tell you much more about the mixture screw setting than the throttle body sync.
The IR temp gauge can be useful as a troubleshooting tool, especially on bikes with lots of cylinders. If one header is substantially different in temp, then you can focus on what is going on with that carb. I can't imagine it being accurate enough or informative enough to adjust anything.
I don't think the IR gun will help you much.
You can search DIY carb sync for instruction to make you own carb sync tool with some clear tubing and a yardstick. There is a "deluxe" version where you connect the two tubes to each other with a small aquarium air valve at the top. A cross-over for lack of a better description. You start with the valve open then slowly close it to increase the sensitivity. That is a nice feature especially when the carbs are way out.
Eric
Have you visited ride reports lately ?. click HERE
ericrat is offline   Reply With Quote
Old 07-07-2013, 05:13 PM   #9
DrMoto
Oddometer: 26
I made my own manometer with four ports to sync an inline-4 after my expensive carb-sync tool failed. Mine was cheap, easy to make, and is quite effective. Lots of pics out there to give you ideas.
'00 KLR250
'07 FJR1300
DrMoto is offline   Reply With Quote
Times are GMT -7.   It's 04:42 PM.
