Old 07-04-2013, 09:37 AM   #1
Philander OP
Someday...
Oddometer: 348
Stuck in Watson Lake, YT with a slowly leaking K60. Ideas?
All,
My brother and I are stuck in Watson Lake Yukon with a slowly leaking K60 on his Super Ten.
We stopped in Toad River and noticed he had a flat. Aired it back up and checked it after 45min of riding, all was good.
After another hour it had dropped 20psi
We have soaped up the tire, valve stem and sides but we can't find any leaks. He has dyna beads in the tires, so we are not sure about dumping a can of slime in there...
Any ideas?
Philander is offline   Reply With Quote
Old 07-04-2013, 09:55 AM   #2
gsweave
Yinz, blinkers are on.
Oddometer: 11,470
Originally Posted by Philander View Post
All,
Any ideas?
resoap valvestem, push it around.
Most suspect area for leak.
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 07-04-2013, 10:34 AM   #3
Garp
Garp's Avatar
Oddometer: 2,445
I had one on the front of my GS that would never seat properly. It would leak slowly until it had lost a few pounds, then it reached a tipping point and went flat in a hurry. No amount of rotating and reseating ever got rid of the problem the only solution was a new Metzler which seated perfectly.
Garp is offline   Reply With Quote
Old 07-04-2013, 10:40 AM   #4
duck
duck's Avatar
Oddometer: 10,403
You definitely don't want to Slime Dynabeads.
Next time try: http://www.ride-on.com/
(Not affiliated. Just a satisfied customer.)
duck is offline   Reply With Quote
Old 07-04-2013, 11:44 AM   #5
Snowbound
Oddometer: 877
I had the same problem . I also tightened the valve stem . My air loss was inconsistent . Best I can say is keep checking and airing up , just don't go over 36 PSI .
Sent from my iPhone using Tapatalk 2
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 07-04-2013, 12:21 PM   #6
Beezer
Oddometer: 5,746
are you sure there isn't a nail in the tread somewhere? if no nail, I would break the bead & scrub the rim, reinflate with some wd40. no need to remove the tire, be near a good source of air
Beezer is offline   Reply With Quote
Old 07-04-2013, 01:00 PM   #7
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,930
Soap the valve core. There might be some sort of issue with the Dynabeads fouling the seal.
If all else fails, remove the beads and put a tube in the tire. Run a rag through it first to make certain that there isn't something really small that's causing the current leak.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 07-04-2013, 01:18 PM   #8
Tim McKittrick
Oddometer: 1,717
The only issue I've ever had with dynabeads was interfearance with the valve stem- I'd remove your valve stem core with it up high so any beads would be down in the bottom of the tire, clean it and the threads, reinsert and test.
And as Bigger Al said, if all else fails you can insert a tube.
Tim McKittrick is offline   Reply With Quote
Old 07-04-2013, 06:24 PM   #9
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,579
Just put a tube in it
Flashmo is online now   Reply With Quote
Old 07-04-2013, 08:33 PM   #10
perterra
perterra's Avatar
Oddometer: 7,400
I had a valve stem that would blow down for no reason. Air it up, would last 3 or 4 days with out losing a pound. take it out for a ride and bring it in, still correctpressure, get up the next morning it would be flat. Air it up, might go another week, then go down on a ride.
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 07-05-2013, 10:12 AM   #11
Philander OP
Someday...
Oddometer: 348
So, we are at Yukon Yamaha in Whitehorse. We limped to Whitehorse at 100kph, stopping every 40 minutes to air up the tire. The pinch bolt for the rear tire was seized, and my brother was nervous about heating the assembly to get it out.
Turns out it was leaking from the bead. Bit of rim damage. So now they are sanding out the burrs on the rim and we are both getting Ride-on put in our tires.
This place is awesome. Thanks for the replies!
Old 07-05-2013, 10:48 AM   #12
yamalama
wet coaster
yamalama's Avatar
Oddometer: 1,214
nice.
Have a GREAT RIDE.
yamalama is online now   Reply With Quote
Old 07-05-2013, 11:06 AM   #13
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,794
Ride-On
Something to be aware of with this stuff if you have never used it before.
After the bike sits (depending on how much is put in) you can have a head shake or weird vibration after first starting off.
That is due to it settling into the bottom of the tire. Just keep riding for a bit it will distribute itself in a few minutes or miles depending on how cold it is.
First time this happened to me freaked me out.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 02:11 PM.
