Old 07-04-2013, 01:20 PM   #1
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 384
Remove handlebar compression fitting? How??
I have hand guards that bolt into rubber compression fitting. I'm trying to get that fitting out to install a new bar.
Can't make them move.
My best idea so far is cut the bar an inch past where (I think) the compression fitting ends, soak in WD40 and tap out.
There's got to be an easier/better way.
What you say?
TIA
Be yourself. Everyone else is already taken.
Yakima is offline   Reply With Quote
Old 07-04-2013, 01:23 PM   #2
duck
duck's Avatar
Oddometer: 10,403
Hard to know exactly what your talking about w/o a pic but I use a 6" extension for a 1/4" ratchet to pull rubber handlebar mounts out of fork trees.
duck is offline   Reply With Quote
Old 07-04-2013, 03:33 PM   #3
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,260
rubber? what you describe sounds like a boat plug type thing,,, should just loosen and pull out.
on everything ive seen you loosen the bolt, then give it a tap with a hammer to push the wedge out of the sleeve and the whole assmbly slides right out of the bar.
2 SPOT is offline   Reply With Quote
Old 07-04-2013, 04:11 PM   #4
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 384
Yeah, a foto would be nice, but's inside the 'bar.
The hand guards attach with a bolt which fits into a threaded split piece of metal, like a tube, cut diagonally. Threading in the bolt causes the two pieces to pull together, effectively enlarging the diameter and jamming the tube against the 'bar.
Compounding things is a piece of rubber jammed into the bar through which the bolt also goes.
Bolt is out, the jammed pieces are still tight (I think) and the rubber is still tightly in place.
In profile it's
Metal/rubber/handlebar with the metal piece extending in to the bar.
Confused? No? Should I keep trying?
Old 07-04-2013, 04:18 PM   #5
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,260
ahh thats your problem, thread the bolt back in a few turns and tap it with a hammer, once it pops in you can pull the whole thing out.
Old 07-04-2013, 04:53 PM   #6
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
+1 and also shoot some WD40 or other oil in there, once the rubber starts moving it won't fight you anymore if it is oily.
GreaseMonkey is offline   Reply With Quote
Old 07-04-2013, 10:45 PM   #7
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 384
Cool. Thanks!
Times are GMT -7.   It's 12:21 PM.
