Old 07-04-2013, 07:31 PM   #1
indr OP
Oddometer: 501
Spring bolt broken in clutch basket
indr screwed with this post 02-22-2015 at 09:18 PM
indr is offline   Reply With Quote
Old 07-04-2013, 07:48 PM   #2
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,433
Take the basket off, put it on a milling machine, plunge a carbide end mill. Restore threads as needed, M6 usually.
Old 07-05-2013, 12:21 PM   #3
ttpete
Rectum Non Bustibus
Oddometer: 6,162
The problem is that unless you know someone with a milling machine who is knowledgeable enough to do it properly, it'll be cheaper to just buy a new basket. Commercial shop time is expensive.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 07-05-2013, 01:23 PM   #4
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Originally Posted by indr View Post
...........While I look for clutch baskets on eBay, feel free to laugh and maybe give some advice about what I can do without having to buy a new basket.
Look for a new central nut as well.
Any good welder close by?
lnewqban is offline   Reply With Quote
Old 07-05-2013, 03:19 PM   #5
joexr
Oddometer: 3,773
He needs a good MECHANIC close by too. STEP AWAY FROM THE MOTORCYCLE.
Old 07-05-2013, 05:52 PM   #6
WayneJ
City Slicker
WayneJ's Avatar
Oddometer: 6,211
All fixed now.
Do you own a torque wrench now?
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 07-05-2013, 06:11 PM   #7
red rider 391
red rider 391's Avatar
Location: turn left where the old hollister barn used to be
Oddometer: 136
broke bolt
Try this ,It worked for me . Get a drill bit just a little smaller then the bolt . If you can start it real slow ,just push hard enough to get the Bolt it self to turn ,,Thats right ,turn in and all the way to the other side ,where you should be able to get a grip on the treads with some pliers and just unscrew it from the back ! worked for me ,try it ! Just try to spin it all the way in !,til you can get a grip on it !Those threads are not hurt !If it was going in really easy ,you can do this !
red rider 391 is offline   Reply With Quote
Times are GMT -7.   It's 11:08 AM.
