Old 07-05-2013, 07:21 AM   #1
Trailhound OP
Oddometer: 5
Yamaha dt230 big bore kit
G'day fellas I'm new here so sorry If this is in the wrong spot but I was wondering if you guys could answer a question for me We got given a Yamaha DT230 L for free and has everything on it that we need to rebuild it but the Cylinder is scratched so I was wondering if I could get a stock YZ 250 big bore kit in it
Cheers Trailhound
Trailhound is offline   Reply With Quote
Old 07-05-2013, 06:44 PM   #2
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
yz250 is 66.4 mm x 72.0 mm
dt230l is 66.8 mm x 64 mm
so that's a no. not a drop in. unless you: trench cases, change rod/crank/etc etc. etc etc etc. lotsa work.
current bikes
stainlesscycle is offline   Reply With Quote
Old 07-05-2013, 06:53 PM   #3
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,502
The DT230 is a big bore DT200....it started life as a 125, stretching to 250 is a bit much. The DT125 is an almost identical bike, lots of parts fit the 230.
motu is offline   Reply With Quote
Old 07-07-2013, 02:21 AM   #4
Trailhound OP
Oddometer: 5
thanks for the replies fellas i was just curious because my cylinder has a few scores in it and instead of paying over $1000 for a new cylinder i thought i could bore it to a 250 but i guess ill just get it re chromed
cheers trail hound
Old 07-07-2013, 03:16 AM   #5
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,741
Check this thread out too
http://advrider.com/forums/showthread.php?t=715716
Cheers Trailhound
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 07-07-2013, 04:07 AM   #6
Twin-shocker
Oddometer: 1,673
cheers trail hound
Why not see if a big bore cylinder for a Blaster will fit? If it does then I would guess cost would be a lot less than re-plating.
Old 07-07-2013, 10:14 AM   #7
stainlesscycle
Oddometer: 2,261
plate it for $150-$200 and be done with it. if you're gonna play with porting - now is the time. basically impossible to port after nikasil is on..
current bikes
Old 07-07-2013, 10:18 AM   #8
Twin-shocker
Oddometer: 1,673
I get the feeling the OP is interested in a cost effective way of getting his bike running properly again, and probably not interested in "porting" which is something that costs a fair amount of money, and in almost every case makes the modified bike much more difficult to ride.
Old 07-07-2013, 10:57 AM   #9
stainlesscycle
Oddometer: 2,261
dang, i forgot. professor twin-shocker is in the house
replating is the most cost effective way. cheaper than any other method. he did mention big bore, so i suggested now was the time to port since a big bore is not going to happen - i assumed he wanted more power.. proper porting does not make a bike more difficult to ride. you can port for performance in any area. a big bore kit would cost more than porting/replate.
current bikes
Old 07-07-2013, 11:41 AM   #10
joexr
Oddometer: 3,773
What kind of oil should he use?
Old 07-08-2013, 10:39 AM   #11
Twin-shocker
Oddometer: 1,673
In almost every case "porting" will make bikes more difficult to ride, as in most all cases this relates purely to extending post open times, which will make peak power occur at much higher RPM, and in many cases will be less than the stock porting would provide.
An inexpensive way of dealing with a worn cylinder, would be a cylinder kit intended for a Yamaha Blaster, but obviously the OP would need to find out whether this would fit his bike properly.
Old 07-08-2013, 10:47 AM   #12
dpforth
no inline fours
dpforth's Avatar
Oddometer: 309
I believe the Blaster was only aircooled.
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 07-08-2013, 11:20 AM   #13
Twin-shocker
Oddometer: 1,673
Dohhhhhhhhhhhhhh.................my mistake! No problem at all admitting I am completely wrong.
Old 07-08-2013, 08:33 PM   #14
joexr
Oddometer: 3,773
Cheers Trailhound
How deep are the scratches? Do you see them or can you feel them?
Old 07-08-2013, 08:42 PM   #15
joexr
Oddometer: 3,773
Porting does not make a bike harder to ride. The power peak may be at higher RPMs , but this is determined by the pipe as well. MUCH higher RPMs , no. More power , yes.
Times are GMT -7.   It's 04:58 AM.
