Old 07-05-2013, 08:11 PM   #1
Queen of Spades OP
tall drink of water
Queen of Spades's Avatar
Oddometer: 978
LC4 shock linkage - how is this bold removed?
While replacing chain & sprockets I decided it would be prudent to check out the linkage bearings, clean and regrease everything.
So far everything feels tight and only one of the linkage bolts looked slightly less greasy (the upper pivot arm bolt, where it attaches to the swingarm). The rest had a healthy coating of grease from the last disassembly.
I'm having trouble seeing how to remove the final bolt, which holds the dog bones to the frame. There isn't enough room to slide fully to the side right now. What else needs to come off to remove this bolt?
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-05-2013, 08:20 PM   #2
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,786
That nut on the left needs to come off as well as the dog bone, then the shaft should slide to the right through a hole in the frame. Chain guard might be blocking the hole at the moment. I believe you can just tilt the guard up.
Right side of the shaft should have a hex end that you can get a wrench on so you can break the nut loose. Or just crank against the dog bone.
Old 07-05-2013, 10:25 PM   #3
bmwktmbill
Traveler
Oddometer: 5,218
Ya, like a 10mm wrench?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-06-2013, 09:35 AM   #4
Queen of Spades OP
tall drink of water
Oddometer: 978
bill
8mm. The bolt was so grimy I didn't notice the hex head.
I had to remove the chain block for the shaft to slide over enough to remove.
Now, off to the sink to scrub all this down.
Queen of Spades screwed with this post 07-08-2013 at 07:15 AM
Old 07-06-2013, 10:37 PM   #5
bmwktmbill
Traveler
Oddometer: 5,218
Thanks for that Spades.
b
Bill Shockley
Old 07-13-2013, 05:15 AM   #6
Alik
viertaKTMotor *****
Oddometer: 266
The shock looks like it would need some attention too. The rubber o-ring looks a bit chewed up...
Alik is offline   Reply With Quote
Old 07-13-2013, 07:12 AM   #7
Queen of Spades OP
tall drink of water
Oddometer: 978
The plan is to get a heavy duty spring, then have the entire unit rebuilt possibly revalved.
Old 07-13-2013, 06:52 PM   #8
Droptarotter
Oddometer: 1,296
Drill and tap the frame for a grease nipple installation while you have the shaft out!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Times are GMT -7.   It's 11:39 PM.
