Old 07-06-2013, 06:26 AM   #1
FredRydr OP
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,458
Need to straighten alloy handbars
Fellow inmates,
I have two or three slightly bent OEM BMW handlebars from F800GSes. I took them to a local autobody shop to straighten, but they said they were unable to help me because the bar simply returned to its current shape. I suspect a motorcycle frame shop would be more experienced dealing with these alloys.
Can anyone recommend a motorcycle frame shop, especially in Pennsylvania or Maryland?
Fred
FredRydr is online now   Reply With Quote
Old 07-06-2013, 07:07 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,097
No one in their right mind would attempt to straighten aluminum bars. Once their bent their trash.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-06-2013, 07:39 AM   #3
Sevv
Oddometer: 99
Aluminum cracks when bent then bent back. Last thing you want is to have them break right through mid turn.
Sevv is offline   Reply With Quote
Old 07-06-2013, 07:42 AM   #4
FredRydr OP
FredRydr's Avatar
Oddometer: 2,458
A sweeping opinion. If the comment about aluminum even applies, what is the basis of this belief?
Old 07-06-2013, 07:50 AM   #5
Trialsguy
Oddometer: 178
Another vote for tossing those to the curb and letting your local scrap metal scrounger take them away. Never, ever trust aluminum bars that have been bent once, let alone twice to get back to the original shape. Scary stuff. I've seen the results of a bar break, and the jagged edge rip open someone's forearm from wrist to elbow as they fell forward and went past the break.
If the price of replacing them with OEM Beemer bars is a deciding factor (and I would guess that's fairly high), take them to a bike shop and find some aftermarket ones as close to the shape you like for far less.
Trialsguy is offline   Reply With Quote
Old 07-06-2013, 07:54 AM   #6
broncobowsher
broncobowsher's Avatar
Oddometer: 1,589
Common knowledge in the motorcycle world.
Plenty of us have unbent stuff as kids (hopefully so dad didn't find out) only to have things fail spectacularly later. It's amazing most of us are still alive. With age come wisdom.
broncobowsher is offline   Reply With Quote
Old 07-06-2013, 07:57 AM   #7
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,619
I've worked with alum for the last 13 years. All alloys common in fabrication industry. Just replace them.
And from dirt bike experience I can tell you for certain you can bend them back, but strength will be compromised significantly. A typical dirt bike scenario plays out like this, bike gets wrecked hard and bars get bent. Trail or campsite fix straightens them out enough to work. Next wreck occurs and the bars bend very very easy. I've never broke any, but they do turn to jello after bending.
By purchasing a set of bars it's also a good time to adjust your Ergos and get something that you might like better.
Jayrod1318 is offline   Reply With Quote
Old 07-06-2013, 08:31 AM   #8
FredRydr OP
FredRydr's Avatar
Oddometer: 2,458
Replace even if, say, they just need to be raised an inch on one side? There's no sharp bend.
Thanks.
Fred
Old 07-06-2013, 08:43 AM   #9
Motomedic
Motomedic's Avatar
Oddometer: 2,481
Quit being a cheapskate, save your own ass.
Replace them.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 07-06-2013, 08:50 AM   #10
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,667
Thanks.
Fred
I've repaired the old style 7/8 aluminum bars, it took an overhead gantry crane, a huge vise and a big steel table bolted to the floor. The new tapered fat bars might be a challenge, they're pretty tough.
It's safe and possible, but it's probably cheaper to just replace the bars.
Old 07-06-2013, 09:46 AM   #11
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
................but they said they were unable to help me because the bar simply returned to its current shape..........
Aluminum tube?
http://www.mlevel3.com/BCIT/heat%20treat.htm
http://www.tinmantech.com/html/aluminum_alloys_continued.php
http://www.keytometals.com/page.aspx...umGrades&LN=EN
Heat it up and quickly cool it in water; it will soften enough to be re-bent.
lnewqban screwed with this post 07-06-2013 at 09:52 AM
lnewqban is offline   Reply With Quote
Old 07-06-2013, 12:21 PM   #12
FredRydr OP
FredRydr's Avatar
Oddometer: 2,458
Replace them.
FYYFF
Thanks all for your replies. The good news is it turns out this $290 bar is not bent! I just finished removing all the shit attached to the bar, pulled it off and checked it every which way. The rubber bushings under the bar clamps did their job and were twisted until I loosened everything again. (I did that on the road, but apparently not enough).
Fred
Old 07-06-2013, 01:00 PM   #13
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
not opinion and not belief. its just a fact of a anything thats heat treated,,, times 100 when its an alloy that has been work hardened during a mandrel bending a drawing process.
the above links are good but heres my lamens easy to understand cliff notes version.
the alloy is soft at the factory so it can be worked w/o cracking. during the process it gets work hardened and can become brittle if they dont keep things in order, after its all done it goes through a final heat treating process to get that perfect blend.
when a bar gets bend it gets a localized heat treatment, just like working it at the factory, (brittle) then when you try to straighten it out it goes through the localized process again (more brittle) introducing micro fractures that you cant see but you can hear.
now you could anneal it, bend it to what you want, then give it a proper heat treating and be golden, but the manufacturer has spent millions over the years on getting this process right.
2 SPOT is offline   Reply With Quote
Old 07-07-2013, 08:28 AM   #14
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,275
Throw them away,,,, they are stress hardened and will only get worse with straightening.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
