Old 07-07-2013, 05:26 PM   #16
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
Originally Posted by rocker59 View Post
Auto rotors are constructed differently from those on motorcycles and have venting in the middle on the fronts of many cars. Basically, a double thickness rotor with cast-in ducting for cooling.
It's not unique to cars - double thickness rotors were standard on mid '80s Yamaha XJ900s/ FJ1100/1200s amongst others.
farqhuar is offline   Reply With Quote
Old 07-08-2013, 09:05 AM   #17
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
Originally Posted by Motomedic View Post
I'm sure someone will be along to tell me it wasn't the rotors, the blah blah blah was the reason my brakes were no longer affected by the heat. I for one firmly believe that the cooler the pads stay, the longer I can abuse the crap out of them before they fade. I also believe Wave rotors help keep things cool.
I've had a similar experience with supermoto brakes. Big drilled wave rotors simply work better and there's no argument possible to say that less rotating weight and more efficient heat dissipation doesn't make a difference. If it didn't then the manufacturers wouldn't waste engineering and development time by making them as such. We have what we have now, for products, because of the evolution of the motorcycle over time - and that evolution has proved that drilled wave rotors work better than the opposite.
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 07-08-2013, 09:53 AM   #18
precarious
precarious's Avatar
Oddometer: 558
http://www.motorcyclistonline.com/ho...rcycle_brakes/
Slotted and wave rotors also give the pad more "leading edges" to bite into according to the Galfer rep in the interview. It's all about better feel.
Testing is pretty much unanimous: Galfer brakes work better. But, are they worth the coin for non-competition use? Only if you have a whole lot of disposable cash and don't need suspension upgrades.
precarious is offline   Reply With Quote
Old 07-08-2013, 10:10 AM   #19
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
My 2012 Goldwing has a double thick rotor on the back.
I had a 2008 Honda Fit, couldn't keep stock rotors on the front...drum brake rear, all the braking was from the front...brand new car, pulse/pulse/pulse every time you push the pedal. Installed drilled and slotted rotors, problem never returned and the thing would actually stop.
Old 07-08-2013, 10:43 AM   #20
precarious
precarious's Avatar
Oddometer: 558
I think my buddy's GL1200 had ventilated discs all the way around, and I know my Magna 1100 had ventilated fronts.
Old 07-08-2013, 01:38 PM   #21
Sp4Mike OP
Sp4Mike's Avatar
Oddometer: 224
Originally Posted by señormoto View Post
... If it didn't then the manufacturers wouldn't waste engineering and development time by making them as such.
Use that logic to explain the beak please. But you had my until there.
Sp4Mike is offline   Reply With Quote
Old 07-08-2013, 09:58 PM   #22
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,661
Weeeell, yer beak is supposed to act as a fender and mud deflector when things get so knarley that you have to remove the front fender. Like that is a reality for all us posers. Sort of like needing vented rotors. ;)
AviatorTroy is offline   Reply With Quote
Old 07-09-2013, 12:24 PM   #23
Sp4Mike OP
Sp4Mike's Avatar
Oddometer: 224
Old 07-10-2013, 12:30 PM   #24
WDG
Oddometer: 262
My understanding is that drilling and/or grooving the rotor also gives a place for gasses, that build up under the pads during braking, a place to vent off to. Whether that's true or not, I don't know.
Cogito... Ergo, ZOOM!
Choosing a ride is much too personal to be left entirely to comparisons of spec sheets.
WDG is offline   Reply With Quote
Old 07-10-2013, 02:25 PM   #25
Sp4Mike OP
Sp4Mike's Avatar
Oddometer: 224
Read the article.
Old 07-12-2013, 08:26 AM   #26
WDG
Oddometer: 262
Originally Posted by Sp4Mike View Post
Read the article.
Yep. I should have done that, first.
Times are GMT -7.   It's 05:52 PM.
