Old 07-06-2013, 07:26 AM   #1
Mikef5000 OP
Oddometer: 2,031
Startup Clutch Noise After Oil Change
I did my first big oil change on my new to me 990... 2008 with 30k miles. Did the whole shebang: oil, filter, cleaned both screens, and cleaned the oil jet to the clutch behind the slave cylinder. The clutch had a slight rattle before, that I gather was normal, but now for the first 1 second after starting it, it has a loud almost shrieking noise. I haven't ridden it yet (rain), but I've started it and warmed it up several times, and the noise still happens with every start. Do I just need to get out and ride it? Just doesn't make sense to me that the sound only lasts a second, but happens every time, so I just wanted to make sure I didn't forget or kink something.
I used the Shell Rotella Synthetic.
All screens came out clean, and the filter pleats were straight. Couldn't tell about the clutch oil jet, because I used some slime/glue to get it out of it's hole.
I did notice this oil hose looks near kinked. This normal?
Also threw in a 16 tooth front sprocket, a black dog kickstand 're-locator', an oil drain hose off the upper drain bolt, and flushed the clutch hydraulic fluid.
I saw this sticker that read "California Vehicle"
Do I have a California specific version of the 990? Or are they just 50 state legal and have stickers stating California for that reason?
I had other questions... but this'll do for now. The clutch noise was the big concern.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 07-06-2013, 09:16 AM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
Are you getting any oil on the clutch plates?
Edit: you did check the oil jet. Are you sure it's clear?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 07-06-2013, 12:20 PM   #3
Mikef5000 OP
Oddometer: 2,031
I don't know if it was clear before, but it was definitely clean when I put it back in.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 07-06-2013, 02:21 PM   #4
bikyto
bikyto's Avatar
Oddometer: 2,199
Oil tank valve stuck? Unlikely but possible.
Is the clutch still operating like before other than the sound?
Old 07-07-2013, 03:26 PM   #5
Mikef5000 OP
Oddometer: 2,031
Seems like it just needed ridden. I started it again today, same crazy loud for 1 second. Rode/sounded normal. Didn't make the noise the next 2 starts.
So we should be good!
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Times are GMT -7.   It's 08:11 PM.
