Old 07-06-2013, 02:47 PM   #1
NKOrange OP
Puny homer
NKOrange's Avatar
Oddometer: 185
KTM 640A fuel setting and carb question
So I wanted to try (... somehow these words seem to always be a prelude to disaster )
... Anyway, I wanted to try the low octane fuel setting on my '07 640A. Disconnected the famous brown wire, turned the starter and the bike ran like crap: only ran with choke on full, and even then coughing. Reducing choke made it die.
Ok, bad idea. Connected the brown wire again, no improvement.
The symptoms seem to be a clogged main jet, and a clue is that the bike has been sitting in the garage for a while (yes, I know, I should be getting more ideas about riding and less about playing mechanic ). On the other hand on the last ride (a few weeks ago) there were no problems whatsoever.
Coincidence? Did the jet decide to clog right before I had the bright idea to try the low octance setting? Or did I mess something else up?
I haven't opened the carb yet, and honestly would like to avoid it if the problem is elsewhere.
7 times down, 8 times up. Such is life.
NKOrange is offline   Reply With Quote
Old 07-06-2013, 02:51 PM   #2
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Coincidence.
Old 07-06-2013, 10:33 PM   #3
bmwktmbill
Traveler
Oddometer: 5,218
Tank full?
Theres a drain screw on the bottom of the bowel, you coul drain the carb.
Pull the fuelline off to make sure fuel is coming from the tank.
That's the easy stuff.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-07-2013, 04:57 AM   #4
NKOrange OP
Puny homer
NKOrange's Avatar
Oddometer: 185
Originally Posted by bmwktmbill View Post
Tank full?
Yup.
I was planning to drain the carb and try to turn it a bit so I can open the bowel and access the jet without removing the carb. Is this possible?
Old 07-07-2013, 08:14 AM   #5
johnno950
Oddometer: 1,076
The choke sometimes gets jammed on the 640 adv,choke lever will travel through full motion but choke piston/slug will be jammed in carby body,maybe worth a look
johnno950 is offline   Reply With Quote
Old 07-07-2013, 08:23 AM   #6
Kawidad
Kawidad's Avatar
Oddometer: 4,965
Not a clogged main jet, but a clogged pilot jet. The passages on the pilot are super small and very prone to clogging. The newer formula gasolines used today cause very bad varnishing in a very short period of time. Time for a carby clean.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 07-07-2013, 09:17 AM   #7
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,421
win a chicken dinner!
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 07-07-2013, 11:44 AM   #8
NKOrange OP
Puny homer
NKOrange's Avatar
Oddometer: 185
Ok. Thanks to LaramieLC4 for the manual. I'll get on it.
By the way, which jet is the pilot? The narrow fixed one next to the main? (Didn't see it specified in Laramie's manual)
Old 07-12-2013, 06:49 PM   #9
NKOrange OP
Puny homer
NKOrange's Avatar
Oddometer: 185
The saga continues
Ok, pulled the carb, cleaned everything out, started the bike, idles like a dream. Problem solved, everything worked fine around the neighborhood.
Until...
... I got on the highway. When I hit highway speeds (and 5-6000 rpm) the bike lost power, started coughing and eventually died and won't start again.
I can't see any obvious problems like pinched fuel lines and the like. Everything is connected fine.
So back to the carb? Floater stuck?
Old 07-12-2013, 11:08 PM   #10
bmwktmbill
Traveler
Oddometer: 5,218
Until...
There is a small screen on the fuel inlet pipe...did you clean that?
bill
Bill Shockley
Old 07-13-2013, 05:18 AM   #11
Alik
viertaKTMotor *****
Oddometer: 266
How much fuel is in? Pinched or kinked fuel line or vaccum line to the fuel pump.
Alik is offline   Reply With Quote
Times are GMT -7.   It's 01:49 AM.
