Old 07-06-2013, 05:44 PM   #1
lacofdfireman OP
Oddometer: 744
Question on Akrapovic install on 04 950S (Lots of pics inside)
So I bought me a used Akrapovic of Ebay that said it came off an 05 KTM 950 Adventure so I knew the pipe would work with my bike. The Exhaust mounting clamp is way different than the stock clamp. It came with a carbon Exhaust clamp and before I install it wrong or screw something up I want to make sure I install it correctly. So here is my question. First a pic of the Akra with the Carbon clamp and the stocker of the 950.
Ok the way I figured I would install this is just to buy a bolt than the stock bolt and put a stop nut (Nyloc nut) on the other side and hang the pipe on the inside of the Stock Exhaust mount? Here are a few pics of what I am thinking.
Does this look ok for what I want to do or do I need to put a rubber bushing or something in there? Anyone have a photo of how theirs is mounted up? Hoping to get this installed tonight so let me know if this is right..
lacofdfireman is offline   Reply With Quote
Old 07-07-2013, 12:00 AM   #2
lacofdfireman OP
Oddometer: 744
Nobody has a photo of how they mounted there Akra's? Somebody help a brother out here..
Old 07-07-2013, 12:10 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,576
http://www.ktm-parts.com/mm5/graphic...0005099000.pdf
Peanuts screwed with this post 07-07-2013 at 12:36 AM
Peanuts is online now   Reply With Quote
Old 07-07-2013, 12:36 AM   #4
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 86
Sorry, no pics... but locating it on the inside should work (as long as everything lines up OK...) however, see the spacer mounted on the inside of the original clamp? Ideally you'll need to make / fit a spacer the same into the rubber mount or you'll never get the bolt done up tight and the mount won't provide proper support for the can.
TrentW is offline   Reply With Quote
Old 07-07-2013, 07:36 AM   #5
Peanuts
Peanuts's Avatar
Oddometer: 1,576
If you did not receive them with the cans, you need to check out the parts list on the link I gave you.
Order 2 of these
Part Number: 56505069000
Description: SPACER BUSHING 8,4X12X16
Retail: $3.49
Your Price: $2.97 (15% discount)
and 2 large OD 5/16" washers.
Old 07-07-2013, 09:37 AM   #6
lacofdfireman OP
Oddometer: 744
Thank you so much for the reply. I will get the spacers ordered. Hopefully I can get them before I leave Thursday for my trip if not I might just have to jimmy rig something up for that overnighter.
Old 07-07-2013, 02:10 PM   #7
grant22
grant22's Avatar
Oddometer: 482
I tried to tell you county boy.
grant22 is offline   Reply With Quote
Times are GMT -7.   It's 02:34 AM.
