Old 07-06-2013, 07:17 PM   #1
Nodabs OP
Nodabs's Avatar
Oddometer: 225
How do I reset the service reminder?
I'm getting ready to change the oil and run the valves on my '12 GSA and I wondered if there is a way to reset the service reminder on my dash. I really don't want to spend $300 to have my oil changed. Plus it is 100 miles to my local dealer, I've got better things to do with my time.
Nodabs is offline   Reply With Quote
Old 07-06-2013, 08:13 PM   #2
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,572
Buy a GS911 scan tool. Set it to what ever interval you want.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 07-08-2013, 03:23 PM   #3
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,979
Thumbs down
Complete bullshit that you can't reset the service reminder without a trip to the dealer, or a $300 aftermarket tool. I just ignore the dam thing.
bemiiten is offline   Reply With Quote
Old 07-08-2013, 03:32 PM   #4
Nodabs OP
Nodabs's Avatar
Oddometer: 225
bemiiten, I agree totally. I can change my own oil, thank you very much. I don't want to have a relationship with my dealer. I want to have a relationship with my motorcycle!
I'm thinking a piece of tape is in order!
Old 07-08-2013, 04:42 PM   #5
10Cup
10Cup's Avatar
Oddometer: 2,666
Understand the points of view about the $300 acc so you can reset your service reminder, but I find it a very helpful tool in knowing that everything on my bike is working properly and should I have a problem out in the middle of no where it is comforting to know I can plug it in and find out right away what is wrong in most cases. Reading any fault codes is very helpful as well as getting ride of the ones that do not require warranty repair. (My dealer only sees my bike for warranty repair.)
Also useful in setting the tipper motors and of course in sync'g the throttle bodies. I really like this tool. You can also get one that has blue tooth and do it all from your smart phone. I like to use available technology not fight it. But then just my 2 cents.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 07-08-2013, 04:57 PM   #6
Gillies
Gillies's Avatar
Oddometer: 783
20k bike / $300 tool. I hit my limit Bihac!!!
No... Really... I like my GS911 lots.
Gillies is offline   Reply With Quote
Old 07-08-2013, 05:00 PM   #7
Nodabs OP
Nodabs's Avatar
Oddometer: 225
I just don't like the idea of being forced to toe the line. What BMW is implying is that we're not competent enough to service our own equipment.
How do I not know if the dealer is using the lot boy to change my oil, hell I would if I ran the place. Charge 150 bucks a hour and pay minimum wage.
I stated changing motorcycle's oil in a dealership when I was 12 years old, I sure wouldn't trust anyone!
Old 07-08-2013, 05:08 PM   #8
Yellow Iron
Yellow Iron's Avatar
Oddometer: 3,097
Does any other scan tool work on the GS.
Im picking up the New OTC scan tool on Wednsday
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is offline   Reply With Quote
Old 07-08-2013, 08:10 PM   #9
David13
David13's Avatar
Oddometer: 617
As far as I know, the only thing that works is the GS911 from HexCode in SA.
It does more than reset the service reminder.
Mine has performed operations on many bikes.
dc
David13 is offline   Reply With Quote
Old 07-09-2013, 02:52 AM   #10
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
Welcome to the wonderful world of BMW self maintenance. BMW seems to do everything it can to make it difficult to service a bike outside of a dealership.
Look, if you are going to do your own service, the GS911 is as essential as your helmet. Reset service reminders, reset TB stops, diagnose and clear faults to name a few must have functions.
It is the best investment for your ride that you will ever make. End of story.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 07-09-2013, 03:49 AM   #11
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,667
Just changing the oil isn't a service.
Plus you can't do a "full" service without something like a GS911.... how do you reset the idle motors with it, how do you park the idle motors while balancing the throttles ?, and much more.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 07-09-2013, 04:32 AM   #12
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,603
...and has anyone tried hooking one up to the 2013 GS-W yet?
Old 07-09-2013, 04:47 AM   #13
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,789
It won't work. HEX is nearly done beta testing a new tool for the Wethead. Apparently the new system is vastly different than the old one.
I went years without a GS911. You can adjust your throttle bodies without it effectively enough: http://www.jimvonbaden.com/R1200_TB_Sync.html
Most of what you need to do a "service" is here: http://www.jimvonbaden.com/Tech_Pictorials.html
You can't reset your service reminder, but who cares? You also can't calibrate your throttle bodies, which can eventually cause a lumpy idle, but does no harm. You also cannot reset or read fault codes, but generally not an issue.
On the other hand, local clubs, like mine, often have a pro version of the GS911 that they share at tech days, and I have one I use on other people's bike as needed. It IS a very nice tool to have, though for a single bike it may not be cost effective. Maybe get together with a few locals and buy one together.
Jim
Old 07-09-2013, 04:50 AM   #14
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,667
Not an issue, but also not a service.
I'd imagine what my customers would say if they expect a full service and i give them a bunch of "no i haven't done that, but who cares".
www.gsshop.biz
Old 07-09-2013, 05:36 AM   #15
JimVonBaden
"Cool" Aid!
Oddometer: 53,789
True, as a paid technician you would definitely be required to do these. A home backyard service doesn't hold the same standard, and in the US if you are required to have special tools to complete a service for warranty purposes you would get that done for free from the dealer. In other words, it isn't an issue for warranty, and does not effect the safety or longevity of the bike. It is merely annoying.
Jim
Times are GMT -7.   It's 06:13 AM.
