Old 07-06-2013, 09:55 PM   #1
Queen of Spades OP
tall drink of water
Queen of Spades's Avatar
Oddometer: 854
Lower frame drain plug leaks with new copper washer (LC4)
The lower drain plug on my LC4 continues to seep oil. I got some new copper washers from the local auto store but this seal is still leaking. The threads are not stripped and I don't want to overtighten and make a bad situation worse.
Is the OEM copper washer a must, here? I used a copper crush washer from a brake banjo bolt- same dimension as stock. Also, I cleaned the surface in between oil changes last week. There were no burrs or rough spots. I'm positive it is the lower drain seal - it gets damp with oil and the seal around the 2nd filter is dry.
What gives?
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-06-2013, 11:24 PM   #2
what broke now
Petroleum Brother
Oddometer: 1,379
http://www.permatex.com/products/pro...sealant-detail
what broke now is offline   Reply With Quote
Old 07-07-2013, 01:40 AM   #3
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,007
loctite
try Loctite 5** or Hylomar blue
Rider 101 is offline   Reply With Quote
Old 07-08-2013, 07:00 AM   #4
Queen of Spades OP
tall drink of water
Oddometer: 854
What should the ft/lb or nM measurement be for the lower frame drain plug?
Times are GMT -7.   It's 02:31 AM.
