Old 07-07-2013, 10:57 AM   #1
Matduport OP
Matduport's Avatar
Oddometer: 51
Eh? Side Stand Length
Hi All,
A quick bit of help if you dont mind.....
I have just finished up converting my 950 adv 2004 to S spec's plus, and im working on my stands, problem is, is that i dont know how long to have my side stand to get the bike at the right angle.
So this is where you can help .....
Can someone measure their 2004 S spec adv to see the length and or anyone let me know what angle their bike leans over at on flat level ground ? the best place i have found to measure is the bars in the middle above the tripple clamp. I use my iPhone and got 17 degrees but think that this is a little much, what do you all think ?
Mat
Matduport is offline   Reply With Quote
Old 07-07-2013, 12:15 PM   #2
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,327
I can't measure mine (07 S), cause I've done the CJ kick stand mod (you can send it in to CJ and he'll do it).
You cut off the foot, then weld a big nut (3/4" I think) to the leg, then weld the foot back on to a 6 or 8" piece of all thread. Then you will have an adjustable stand. I like mine a little longer than OEM, or I may change it depending on the load I'm hauling.
Go ahead and bite the bullet and do this mod and you won't regret it....
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 07-07-2013, 12:22 PM   #3
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,779
I found this '05 "S" side stand:
KTM OEM side stand for 2005 Adventure "S" model with tall suspension (may fit other models as well)
331 mm length
http://www.dualsportwarehouse.com/KT...0302320030.htm
Motorcycles . . . my Happy medicine.
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
2014 Wee2,Vee2, NC7X: http://s836.photobucket.com/user/Twm...21297.jpg.html
mcmann is online now   Reply With Quote
Old 07-07-2013, 03:56 PM   #4
RoundOz
Plenty of seasoning
Oddometer: 993
My solution...
I don't think it's possible to have a 9x0 sidestand that works with all loads and in all situations. I made an adjustable one that is fairly light and IMHO not too ugly. It incorporates a tilting bigger footprint too.
http://www.advrider.com/forums/showthread.php?t=618247
One of my best mods and Is so unobtrusive that on my last loaded trip I forgot that I should have shortened it one notch...too many times offroad I couldn't set the stand and get off, due to uneven surfaces. I had a bunch of camping gear on the back and this is enough to screw up the angle of the badly thought out OEM sidestand position...the footprint should be a few inches further away from the centerline of the bike.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 07-08-2013, 05:44 AM   #5
hennessyktm
Oddometer: 39
Stand Lengths
I'm surrently doing the same mod and had the same question(s).
Here is detailed info on stand lengths with part #s off the KTM HOW.
These are the centerstands manufactured for the various models of Adventure;
•2003-2004 "S" Model - 6000302200030 = 379mm
•2003-2004 Standard - 60003022144 = 346mm
•2005-2010 Standard - 6000302240030 = 333mm
•2005 "S" Model - 6000302230030 = 359mm
•2006 "S" Model - 5750302210030 = 378mm
•2007-2008 "S" Model - 6000302200030 = 379mm
•2009-2010 "R" Model - 6000302200030 = 379mm
These are the sidestands:
•2003-2004 "S" Model - 60003023000 = 349mm
•2003-2004 Standard - 60003023100 = 319mm
•2005 Standard - 6000302330030 = 302mm
•2006-2011 Standard - 6010302310030 = 302mm
•2005 "S" Model - 60003023100 = 319mm
•2006-2008 "S" Model - 6010302320030 = 349mm
•2009-2011 "R" Model - 6010302320030 = 349mm
hennessyktm is offline   Reply With Quote
Old 07-08-2013, 06:00 AM   #6
Matduport OP
Matduport's Avatar
Oddometer: 51
my issue is that with the
is a) how do you measure it as there is a bend and the stand from the non s is way longer than is supposedly is
and
b) when i did extend it when i found a way of measuring it the bike was leaning at such a horrendous angle i thought it was going to fall over
there is basically a 30mm extension right ? well to get the bike to a 20 degree lean angle i have had to extend it by about 60mm.
The answer to this will come int he post shortly. I have bought a S stand so i can compare it against the standard and can give you the derivative answer for the future.
Times are GMT -7.   It's 07:55 AM.
