Old 07-07-2013, 01:47 PM   #1
tanker253 OP
tanker253's Avatar
Oddometer: 12
New 2012 990 adventure oil leak
I picked up my new 990 in April 2013. I've put about 4500km on it and it developed an oil leak on the left side of the engine. I removed the tank to take a look but can find any obvious leaks. Seems to be somewhere behind the oil tank. Any ideas? The dealership is 8 hours away so just trying to trouble shoot a little on my own.
2012 KTM ADVENTURE 990
2006 KLR 650
tanker253 is offline   Reply With Quote
Old 07-07-2013, 04:03 PM   #2
tacosupreme
tacosupreme's Avatar
Oddometer: 278
I had the same problem with my new 2012. Turned out to be the hydraulic cam chain tensioner. I found it by dusting the motor with foot powder and letting it run until the fan came on. I put a little bit of anti seize on the threads and tightened it back up, and no more leaks, although I'm sure the "right" way to fix it would be to get a new crush washer.
If that's not it this thread is full of all kinds of options-http://www.advrider.com/forums/showthread.php?t=483183
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 07-08-2013, 07:26 PM   #3
tanker253 OP
tanker253's Avatar
Oddometer: 12
Well damn.. That was the problem. Haven't fixed it yet but I cleaned up the bike then went for a quick spin. Sure enough the source was that plug right behind the oil tank. Thanks!!
2006 KLR 650
Old 07-08-2013, 09:14 PM   #4
tacosupreme
Oddometer: 278
Just be careful when you take it all the way out, the tensioner is spring loaded and will fall out. Might try tightening it a little, I was able to get to mine with a 8mm ball "L" allen.
Old 07-09-2013, 08:00 AM   #5
tanker253 OP
tanker253's Avatar
Oddometer: 12
Thanks for the tip. Not much room to work there. I think for now I'm just going to tighten it a little and see what happens.
2006 KLR 650
Times are GMT -7.   It's 07:54 PM.
