Old 07-13-2013, 11:44 AM   #46
TK-421
not at my post
TK-421's Avatar
Oddometer: 311
It's a shame this has happened to you and I hope BMW does agree to help you out since you're right, this looks like a legitimate parts failure, and not due to neglect or improper service. Way too early for this type of mess...
Thank you for sharing such detailed photos and descriptions, I hope I never have my engine in this state but it's nice to see what's involved if it does ever happen.
TK-421 is offline   Reply With Quote
Old 07-14-2013, 06:44 AM   #47
mondo2000
Oddometer: 10
I would definitely take the pistons out have a very close look at the crowns and ring lands. It appears the engine has suffered from low oil pressure. Do you have any idea what caused that? Was there any oil in the airbox?
IMHO you made the right choice. If you rebuild your old engine at least you will know what you have. If you buy a used engine it will be another crap shoot.
mondo2000 is offline   Reply With Quote
Old 07-14-2013, 10:16 AM   #48
binman41 OP
Oddometer: 20
Gona see if i can borrow a ring compressor from a mate..... The boys are into motocross so im hoping one of them has one and its universal for different size pistons? Should be i think!
There was no oil in the airbox.....cam chain tensioner appears fine.
binman41 screwed with this post 08-03-2013 at 05:10 AM
binman41 is offline   Reply With Quote
Old 07-14-2013, 11:14 AM   #49
BC61
BC61's Avatar
Oddometer: 1,276
If you can't locate a piston ring compressor there are a few shade tree mechanic ways a round it. Rings can often be manipulated by hand particularly when inserting pistons from below. Another trick is a soda/beer can. Cut the ends off so you have a flat sheet of aluminum. Wrap sheet of aluminum around pistons and rings compressing them. Insert into cylinder sleeve, push piston through.
BC Moto Adventures https://www.facebook.com/pages/BC-Mo...2554006?ref=hl
My experience at Dakar 2012 www.bc2dakar.com
BC61 is offline   Reply With Quote
Old 07-14-2013, 11:26 AM   #50
ragtoplvr
Oddometer: 6,632
you will need a new balancer connecting rod too. Anytime the bearing spins, the rod must be resized or replaced.
Rod
ragtoplvr is offline   Reply With Quote
Old 07-14-2013, 01:46 PM   #51
binman41 OP
Oddometer: 20
Thankyou both.
Did not know about the balance rod connector needing to be replaced! The list grows! :(
Old 07-14-2013, 03:24 PM   #52
Icy Roads
Icy Roads's Avatar
Oddometer: 57
Can't wait to hear what BMW has to say....
I really hope they offer you a bunch of parts. They can be a little difficult if the work isn't done in their shops, good luck!
Icyroads
Icy Roads is offline   Reply With Quote
Old 07-14-2013, 10:57 PM   #53
Full Power
Oddometer: 1,602
What is that dark, brown-ish, viscous, syrupy near-liquid coating on the internal engine assemblies?
It looks nearly like an improvised oil substitute.
Could that "lubrication experiment" have been the cause of your bearing seizure?
Warm enough to RAIN is warm enough to RIDE.
Full Power is online now   Reply With Quote
Old 07-15-2013, 06:50 AM   #54
binman41 OP
Oddometer: 20
It appears to be normal Oil to me?
Old 07-15-2013, 09:38 AM   #55
Full Power
Oddometer: 1,602
Any luck finding ' oversized ' bearing shells for the balance rod journal ?
Have you inspected the oil pump for damage, or excess clearance yet ?
It would be nice to discover the CAUSE of damage, prior to replacing parts and re-assembly.
. My untrained eye suspects an oil starvation issue as root cause of bearing destruction.
Old 07-15-2013, 05:51 PM   #56
JRWooden
Oddometer: 4,313
Note:
The Rotax has TWO oil pumps as it is (what I would call) a semi-dry sump design.
and yeah, I agree with Full_Power ... a close inspection for the condition of both pumps is very important!
Old 07-17-2013, 06:04 PM   #57
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 390
Hose clamp for ring compressor
I have used a large hose clamp before. They work really well.
Use along with a piece of aluminum can, as mentioned above, in order to cover over the rough parts of the clamp. (worm gear etc.)
(We call it aluminium on this side of the world)
P.S. great thread. It is very interesting to see the F800 in pieces. My bike is a high mileage ex rental. So I am keen on any information on tearing it down in case I have to do the same one day.
It has done 97,000km. The last 8,000km with me as owner. I have had no issues so far. Apart from LH hot grip which I have fixed. (Following one of the threads here)
Kiwi Tinkerer is offline   Reply With Quote
Old 07-19-2013, 07:20 PM   #58
Icy Roads
Icy Roads's Avatar
Oddometer: 57
Must be waiting for parts
I can't wait to see this puppy going back together.
Icyroads
Old 08-03-2013, 05:04 AM   #59
binman41 OP
Oddometer: 20
Hi All,
Havent been on here in a while so an update to where the bike is.
Contacted BMW Mottorad customer services, they didnt give a monkeys, not even a slight bit of interest in what had happened, why it had happened or how it was going to be fixed....bounced it off them a few times, different letters, different people......and they just didnt want to know.
In my opinion I was left quite pissed that a company such as BMW took this stance. I even asked if they would provide me with spare parts at cost (without theyre very generous mark ups) and even that they werent prepared to budge. Dissapointed in BMW and they have now lost my faith. I know technically they didnt owe me a bean.....but with a bike with not many miles on and full BMW service history i at least expected them to show an interest.
Am still planning on taking it higher and seeing what happens (Ive got nothing to loose). But please all take note off BMW's attitude towards such matters. This was a major engine component, not a small consumable/wear and tear kind of component.
Anyhow.....
I removed the head and pushed the pistons out of the block.....no damage to the bores they look absolutley fine. Head and valves all look good as do the pistons (apart from needing new bearing shells in their associated con rods).
Looked around for someone to replate/grind the crank....no-one around who could do it...... plus I found a second hand (very good condition) for 150.
Priced up the parts i required, with New bearing shelld and stretch bolts, and used crank and balance arm assembly...price was coming in at 650 (with a discount!)
The engine being advertised on Ebay Italy was up for sale for 1200 Euros plus 150 Euros shipping.....i Managed top get it for 1200 euros all in including shipping, so just under 1000.
Engine arrived, is now in the bike all is running and at the moment all is good.
Please note, when i first took the bike out for a spin with the new engine (very carefully) I noticed there was a big flat spot in gears 3 and 4 at mid range through the revs....almost like the bike was hitting the limiter.....but obviously it wasnt......power on through the flat spot and the bike would start pulling again etc. Got me quite woried and I hastily rechecked the valve clearances etc.....however I since learnt that having the battery disconnected for a few weeks will reset the ECU....... the throttle position sensor (TPS) are 'automatically' adjusted on the F800GS' and basically set themselves....... someone mentioned a few hundred miles of riding and the flat sots dissapear as the TPS corrects itself.
I have only done 50 ish miles since the new engines been in and already it is smoothing itself out and the flat spots are no where near the size they were....... ill keep you updated if it resets itself.
Back to the original engine; I see myself having two choices. 1. sell the engine off as broken down spares... think I should be able to get 500/600 quite easily (maybe more)
2. Wait for cheap used crank and balance arm to come up on ebay, rebuild the engine and sell as a complete engine.....(if i do this i will sell with the invite of helping, for free, the buyer fit the engine to their bike so that i am happy i am selling them running engine with the guarantee that if it doesnt work ill take it back and refund complete).
At the moment im holding fire on either option and just making sure that the new engine is completely fine.
By the way.....I found putting the engine back in much easier than taking it out....with careful tagging off all the loom connections, photos and a good mecahnical mind it was quite easy. If I had to guess times, I'd say it took me 8 hopurs to strip (from complete bike with fairings) the bike down and remove engine....and probably 5/6 hours to put a new engine in and rebuild the bike back up. I had my dad help me 'steady' the engine as i was jacking it back up and into the engine...... possible by yourself but easier with two.
Old 08-05-2013, 04:45 AM   #60
luke-eole
Oddometer: 6
Originally Posted by binman41 View Post
Hi All,
Anyhow.....
Congrats on getting it going again!
Mine is on the way to Riders in Cardiff to get checked over, getting towed up by my dad while I am away at work, he didnt have the time to strip it.
Should hopefully hear from them in a few days, they sounded abit mre sypmathetic towards the situation though, just have to wait and see.
Have fun
Luke
luke-eole is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
